Quantcast windshield wiper fuse # - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > windshield wiper fuse #
Old 04-06-2009, 06:05 PM   #1
ttavenieriii
1994 ZJ
i have a 94 grand cherokee 4x4 4.0 and the windshield wipers stopped working check and have no power at wiper motors and not a switch i beleive its the fuse but i have no idea what fuse number it is or which fuse pannel its in i have a fuse pannel on passenger side dash and i have the fuse pannel with the maxi fuses in engine compartment behind battery. anyone have any idea or advice????
thanks in advanced!!!
ttavenieriii is offline   Reply With Quote
Old 04-06-2009, 07:07 PM   #2
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Front Wiper: Fuse #27 on the passenger side kick panel.
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Old 04-06-2009, 08:12 PM   #3
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
ZJ Fuse Diagram / Fuse Listing / Fuse Location / Fuse Panel / Kick Panel / Power Distribution Center / PDC
(Hopefully that takes care of the search key words!)
Schematics: Top is the Kick Panel on the passenger side (North America Passenger side)
Bottom is the PDC / Power Distribution Center under the hood
KD8EBC
'94 ZJ 5.2 LTD
Old 06-13-2009, 04:22 PM   #4
MedicDB
Does anyone know how to get rid of the ABS dash light after the ABS fuse is pulled? I have a 94 5.2 ZJ and the ABS sucked anyway so I yanked the fuse. I tired fuse 15 in the cab and fuse 8 under the hood and either will kill the ABS but both will activate the ABS dash light. I have tried pulling them 1 at a time both ways and both same time.
MedicDB is offline   Reply With Quote
Old 06-13-2009, 07:21 PM   #5
Mickey_D
The Great White Ghost
Mickey_D's Avatar
Medic, any fault at all in the ABS system will trigger the light. That includes a loss of power. The light is turned OFF by applying power to the system. The only way to get the light to turn off is either having a fully functioning ABS system or removing the light bulb itself.
A big thank you to whomever sponsored my membership!!
1974 CJ-5 258 3spd SOA on 31's [Sold in 1991]
1995 ZJ Limited 5.2 on 31's [Sold in 2009]
1990 XJ Laredo 4.0, nothing special [Sold in 2010]
1955 Willys CJ-5 #12171 [Sold in 2011]
1997 ZJ Limited 5.2 The Great White Ghost
1953 Willys M100 trailer
Mickey_D is offline   Reply With Quote
Old 10-01-2009, 04:18 PM   #6
FortCollinsZJ
Not true, pull the relay in the fuse box under the hood, and the ABS fuse in the interior fuse box, bye bye ABS light.
Had to do it when I put in the 8.8 - ABS.
Nothing here
FortCollinsZJ is offline   Reply With Quote
Old 12-27-2009, 03:55 PM   #7
vjsmith
1996 Grand Cherokee Fuse Panel
1996 Grand Cherokee Fuse Panel Diagram (passenger side kick plate to find, Owner's Manual pgs 205-206):
1 2 3 4 5 6
7 8 9 10 11 12
13 14 15 16 17 18
19 20 21 22
CAVITY FUSE DESCRIPTION
1 10 amp (RED) Radio
2 15 amp (Lt Blue) Cigarette Lighter
3 10 amp (RED) Rear Washer Switch, Body Controller
4 10 amp (RED) Airbag
5 10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II
6 15 amp (Lt Blue) Vehicle Information Center/Graphic Display
Module Park & Side Lamps, Overhead
Console Lighted Visor, Automatic Dimming Mirror
7 20 amp (Yellow) Body Amp, Cluster, Body Controller
8 20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo
Lamp, Trailer Tow
9 15 amp (Lt Blue) Brake Switch
10 10 amp (RED) Rear Window Defroster
11 10 amp (RED) ABS Module
12 10 amp (RED) Heater-Ventilation-A/C Control & Recirculation
Motor
13 15 amp (Lt Blue) Hazard Switch, Turn Signal Switch
14 15 amp (Lt Blue) Spare
15 15 amp (Lt Blue) Spare
16 10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp,
Halo Lamp Cargo Lamp, Underhood
Lamp, Dome/Read Lamp Right & Left Visor,
17 15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display
Module, Park & Side Lamps,
Headlamp Switch, Body Controller
18 20 amp (Yellow) Spare
19 15 amp (Lt Blue) Passing Light
20 15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle
Information Center
21 15 amp (Lt Blue) Power Outlet
22 10 amp (Blue) Airbag Module
vjsmith is offline   Reply With Quote
Old 12-18-2011, 06:19 PM   #8
cali7312
can anyone get a diagram for a 98 GC fuse kick panel?
(Totaled)-1998 ZJ: 3" Coil Spacers, Zone Shocks, Rustys Track Bar, 32x11.5 BFG A/T
(Current)-1998 ZJ: 3" Skyjacker SA Lift, 32x11.5 BFG A/T, Baja-8 ; 33x12.5x15 Interico Truxus M/T, Quick Discos
Wrenching on soon: Front + Rear Adj. Trac Bars, 2" Pucks, 35s.
cali7312 is offline   Reply With Quote
Glock Forum
