Quantcast Windows not working...what givevs? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Windows not working...what givevs?
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 07-14-2007, 09:46 PM   #1
LunchBoxmtbr
2004 Grand Cherokee 4x4: The windows all of a sudden stopped working. None of them will roll down, and the driver side window, mirror, and door lock controls are dead. I pulled the panel, and everything is hooked up, and looks good. I also browsed the manual, and cannot find any reference to a fuse that controls the power windows/door locks. The passenger door lock works, but not the window. When I press the keyless lock when exiting the Jeep, it doesn't lock the driver side. It seems to me like the wiring harness is loose somewhere, but I can't find where it connects under the hood. It makes sense that the driver side, arm rest control panel runs the whole vehicle, so it would seem it's come loose...but from where?
Anyone had this happen, or have any ideas?
Thanks!
LunchBoxmtbr is offline   Reply With Quote
Old 07-14-2007, 10:55 PM   #2
texasmail1962
I had the same problem. Check inside the wiring harness where the drivers door hinges. Had some wires to break.
texasmail1962 is offline   Reply With Quote
Old 07-14-2007, 11:17 PM   #3
LunchBoxmtbr
Thanks...I'll check that.
Old 07-15-2007, 05:27 PM   #4
LunchBoxmtbr
That was it...the main power wire inside the rubber boot broke in half. All better now! Thanks!!!
Glock Forum
