Windows don't work, doesn't turn over. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Windows don't work, doesn't turn over.
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 04-20-2013, 01:27 PM   #1
Shane7
My friend is struggling with her 97 4.0L ZJ Laredo. The windows don't go up or down and every time she goes to start it, literally nothing happens. No gauges, doesn't even turn over. I fiddled around with the BCM (09AE) and everything clicked back on and I started it right up, then while running, everything went dead again. I swapped out four different BCM and not a single one worked. I picked up another 09AE from the bone yard and that had no results. For ****s and giggles I tried two different 09AF modules and obviously, nothing. I then lastly tried the 09AE from my 98 ZJ and even still got no results in hers. Both her factory BCM and the 09AE I have started my Jeep, but it then kicked off, probably because of my alarm system, I'm guessing. (Hers has no alarm system)
So, with all this I'm lead to believe it isn't her BCM but maybe a wire shorted or the plug? Anything else it could be?
Shane7 is offline   Reply With Quote Quick reply to this message
Unread 04-20-2013, 02:16 PM   #2
Shane7
Anybody?
Unread 04-20-2013, 03:55 PM   #3
KoreaZJ
1994 ZJ
Clean/tighten battery both cable connections on BOTH ends. Make sure grounds are clean/tight.
How old is battery? Had it tested?
KoreaZJ is offline   Reply With Quote Quick reply to this message
Unread 04-20-2013, 05:22 PM   #4
Shane7
I cleaned the terminals and checked the ground. I get power to everything but the radio, windows and gauges. It just doesn't turn over... Nothing happens when I turn the key.
Unread 04-20-2013, 11:02 PM   #5
jabba974
Have you tried the ignition switch?
jabba974 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2013, 09:07 AM   #6
Shane7
Would that really prevent the gauges, windows and radio from working? Could it be a relay under the hood?
Unread 04-22-2013, 06:12 AM   #7
Shane7
Anybody?
Unread 04-22-2013, 06:13 AM   #8
Shane7
I'm going to try it today I think... won't I need a matching key for it? I'm new to this stuff..
Unread 04-24-2013, 08:19 PM   #9
jabba974
I believe the ignition switch is sperate from the key/lock tumbler....you'll need a set of tamper resistant torx bits to take it out... It could affect the other electronics from working if power isnt supplied to the accesories...and it should be cheap enough to replace.. Good luck!
Unread 06-24-2013, 02:02 PM   #10
zjsean
Just had the same problem. Don't know if you figured out your problem yet. But, to make a long story short, I found frayed wires in the dash. Had to take the entire dash pad out to find it. The wires run down from the radio and out underneath the passanger air bag. There were about 5 wires that were frayed and fried together were they run out of the dash.
zjsean is offline   Reply With Quote Quick reply to this message
Unread 06-24-2013, 02:18 PM   #11
ZJNewbi3
Did you check all relays and fuses?
ZJNewbi3 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2014, 09:42 PM   #12
DawnC
I also found 5 wires behind glove compartment that were frayed on 97 laredo.
DawnC is offline   Reply With Quote Quick reply to this message
