Quantcast windows arnt working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > windows arnt working
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 07-11-2008, 12:23 AM   #1
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
this is a 1998 ZJ, 5.9 limited.
ok, today they were working, and now they are not.
none of them are working, at all...
it is dark and late, so i was unable to check the fuze, ill bet that that is the issue, but i want to cover all possibilities.
they arnt making any sounds or nothing, just.... no movement.
thanks.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/
5.9 ANDY is offline   Reply With Quote
Old 07-11-2008, 06:41 AM   #2
Turbonut
Not much to add other than a circuit breaker or fuse problem. If that checks out OK, check for power at the driver's door along with a good ground. Have seen a broken ground wire cause this problem also.
Years ago on a Buick I owned, no power windows, it was a broken wire the flexible harness between the door and body.
Good luck and hope it's a simple fix.
Turbonut is offline   Reply With Quote
Old 07-11-2008, 08:46 AM   #3
grandpapy
if it's like most vehicles main power goes from the fuse to the driverside switch assymbley if the fuse is good and no shorts or broken grounds i would change the driver door swith assembly you can ark some wires and see if the other side starts to work. enjoy!
grandpapy is offline   Reply With Quote
Old 07-11-2008, 11:29 AM   #4
-Joe-
forget about them, leave them up and use your a/c
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Old 07-11-2008, 01:11 PM   #5
Marcos
Are your door locks working? On the later models (after 95), the windows and locks are all controlled by the door modules. The modules get one main + and - wire each, and then power the accessories directly, with no fuses in between. If the locks work, then it's probably not a power/ground/fuse issue.
Marcos is offline   Reply With Quote
Old 07-11-2008, 01:50 PM   #6
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
yea, there is a slight issue with that.
and thank god at least the front 2 are stuck down.
Old 07-11-2008, 01:53 PM   #7
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
just went out and checked, the windows wrok now.... it must have fixed itself..... the JEEP gods have smiled uppon me.
Old 07-12-2008, 04:11 PM   #8
grandpapy
hmmm... sounds like bad ground or driverside switch assembly look into that. i'm sure it'll happen again.
Old 07-12-2008, 07:00 PM   #9
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
as long as it happens when they are down.... or it will be like a swet box....
Old 07-13-2008, 12:41 AM   #10
cologc46
Jeep Owner since 73
cologc46's Avatar
Odds are you have a bad wire in the door harness. Same thing happened to me last week... at end of a trail, went to roll up the windows and all 4 were dead. I had broken wires in that harness about 5 years ago. I thought, broken wire again. So, I opened the door a crack with my finger on the window switch. Sure enough, as I slowly swung the door open, I found a spot where the wire made contact and was able to roll up the windows. Next day I spent pulling out the wiring harness and rewiring the broken ground. While I was at it, I fixed several other, soon to be broken wires.
Next time your windows fail, try moving the door and see what happens. Might be a broken wire.
His: Kacki 06 Rubicon. 4.0L w/ Amsoil Hi-flow intake, catback exhaust, and fogmod OPDA. Rubicon black alloy wheels, 315/75/16 Goodyear MT/Rs with Staun internal beadlocks. RE 4.5" extreme duty LA lift & belly pan w/ Currie antirock front swaybar. D44 tru-loc axles geared @ 4:88. Jeep Hi Clearance Front Bumper, Warn rocker guards, Warn rear bumper & spare rack, and XD9000i winch w/ Amsteel rope. Yaesu ham radio. Midland CB.
Hers: White 03 WJ Limited, 4.7L, Stock.
Daughters: Red 97 TJ, 4.0L, Stock.
Colorado Jeep Club Member #132
cologc46 is offline   Reply With Quote
Old 07-17-2008, 08:33 AM   #11
ISUzj
1994 ZJ
Hey did you pull the door off of your ZJ and rewire them? or how did you go about it. My windows have completely stopped and I guarantee it is a wire in b/t the door. I checked; and out of the 23 wires I need to replace 12 of them...
did you reconnect them before the door grommet or inside the jeep or where?
So i plan on taking a Saturday fixing the sagging door and while I am at it completely rewiring that harness.
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
My Build Thread Align your jeep yourself B N B#175
ISUzj is offline   Reply With Quote
Old 07-17-2008, 10:01 AM   #12
IdahoZJGuy
I had a similar issue like this with mine last week. Intermittent issue was driving me nuts. I checked everything - I thought. Long story short - the problem was in the switch on the door with the problem. I took it apart (four tangs on each side, pry apart with small screw driver) and found that the little metal contacts (there are two of them in each switch) had gunk built up on the contact points. If you use a rubber eraser (end of a pencil) and clean the contact points on the switch and then reassmble the switch carefully (tangs like to fall shift off floating point if you assemble too fast) and connect back to the wires before you put the panel on that may fix the problem. It did mine.
Since then I have been up and down mountains, gulleys, etc. Lot's of rolling and rocking. Still works fine - now if can just fix my transfer case problem; I'll be back out in the woods soon.
IdahoZJGuy is offline   Reply With Quote
Old 07-17-2008, 04:45 PM   #13
elmer_fud
see my instructions here
http://www.jeepforum.com/forum/f13/93-zj-door-harness-problems-547456/
i think the wiring changed between 95 and 96 though, so this will not work for Andy
Brian
95 ZJ, 5.2 V8,160,000 miles
Colorado Jeep Club member Pi
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline   Reply With Quote
Old 07-18-2008, 01:12 AM   #14
cologc46
Jeep Owner since 73
cologc46's Avatar
Kyvang: I searched the forum, and found the thread that elmer_fud linked in his post above. That inspired me to pull the harness and do a much better job fixing the broken wires than I did about 5 years ago. My sloppy job back then, working in the crotch of the door, holding back that rubber boot, etc, lasted a lot longer than I thought it would. I am hoping that this latest repair will be the last even longer.
The trick is finding the magic key on the 2 connectors under the dash, which releases the connector. There were several decoys on my connectors that led to a lot of cussing. Once those were apart, I had the harness out on the bench, fixed, and back in the jeep in an hour. YMMV.
Glock Forum
