Window Won't Work, Not Regulator - JeepForum.com
post #1 of 6 Old 11-09-2007, 09:51 PM Thread Starter
Briandl
So the other day my wife rolled the back passenger side window down, she reported that the window wouldn't go down from the drivers side controls so she put it down at the door.
No pops, the window didn't fall or anything like that, it just went down and wouldn't come up again.
So I took the window off the regulator, used some zip ties to hold it up, took out the regulator and put 12V to it, it works fine, and the common failure is not present, the plastic piece that holds the cable in place is intact.
I put a multimeter on the connector for the motor and I can see it switch polarity but it doesn't get 12V.
The lock works, the speaker works, and the switch light turns off and on when the window lock out is turned on.
I guess I can work my way back and see if I can find out why I don't have any power back there, but any ideas would be appreciated.
All of the other three power windows/door work fine.
TIA
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #2 of 6 Old 11-09-2007, 09:57 PM
SurpriseWJ
check the switch just because the light comes on doesn't mean its bad.
2000-WJ Laredo
4" IRO Long Arms and Adjustable short arms in the rear, A-arm spacer, JKS discos and Bar Pin Eliminators, Dual Steering Stabilizer, 265/75R16 Pro Comp Extreme MT's, CV front Driveshaft, D-35 Rear Aussie Locker, Painted cladding (Working on building sliders)
SurpriseWJ is offline
post #3 of 6 Old 11-09-2007, 10:03 PM Thread Starter
Briandl
I got a multimeter so no problem, but it won't work from the drivers side or the door, and when using the drivers side I can see the polarity change as I go from up to down.
Thanks for the suggestion.
Briandl is offline
post #4 of 6 Old 11-09-2007, 10:28 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
If you are getting voltage from the driver's switch, and the door's switch, it must be a bad motor on the regulator.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 6 Old 11-09-2007, 11:29 PM Thread Starter
Briandl
I was wrong, the motor was getting power, I should have known it's like everything else, it gets power all the time and ground completes the circuit.
Anyhow, it's working now, the only thing I can say I did was move the regulator all the way up using 12V directly from the battery, after that it started working again.
If I had to guess I'd say there was a problem with the motor, it's on it's way out or some problem with the brushes in the motor.
I guess it could be a short somewhere, or the switch could be going out, but switches usually just go out, they don't go out slowely.
Briandl is offline
post #6 of 6 Old 11-09-2007, 11:31 PM
superarmen
i have had that happen to me before...luckily it was just a fuze...that is probably the first thing you should check and is also the easiest to fix....
99 WJ in BLUE
94 YJ in BLACK
superarmen is offline
Window regulator...One more of the many.... JPK ZJ Grand Cherokee Forum 0 09-15-2007 02:40 PM
Window regulator for a '99 Stoli ZJ Grand Cherokee Forum 1 03-26-2006 04:32 PM
Detaching window glass from '02 window regulator? dotspace ZJ Grand Cherokee Forum 3 08-04-2005 07:23 PM
Bad window regulator? cherokeepower ZJ Grand Cherokee Forum 0 01-13-2003 05:16 PM
