#1 | |
Window vent visors
I am planning to install vent visors in my 01WJ.
I'd like to use the in channel type and I'd like to know if they will interfere with the windows closing. What happens to the window seal, does it have to be removed? If not how wiil the visor fit?
#2 |
Jeep Jedi Master
Here's a link with tons of info.
http://www.weathertech.com/store/vehsearch.asp?item_group_id=4&make_id=27&year_no=2 001&veh_id=324&veh_opt_choice_id=0 Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
#3 | ||
Confirmed Street Jeeper
We put the Weathertech vent visors on both of our WJs.
My only complaint is that there is a Weathertech emblem on each visor that is stuck on very securely. The emblems are not very obtrusive but if you don't like them, you have to work carefully to get them off without scratching the plastic.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R). |
#4 | |
Are they worth it? |
#5 | |
#6 | |
It's pretty cool how that thin little flange just slips into the channel. I say they are worth the $$. Yeah, those stickers are NOT coming off! ![]() |
#7 |
Wish they made the in channel ones for the ZJ
Jesus is coming. Look busy. |
#8 | |
Russ 02 Dakota Quad Cab 4.7 5 spd 93 ZJ Stolen and wrecked Mar29/08 |
#9 |
Autovent shade also make in channel ones for the WJ. Thats what I have on mine. They stick into the channel by double sided tape. The only problem I had with mine was that I put mine on when it wasnt so warm outside and probably should have cleaned the channel a bit better as the came loose. called AVS and they sent me new tape. They look good no big emblems.
[SIZE="1"]04' WJ Laredo 4.0L 4x4 245/75-16 GY MTR's Rusty's 2" BB ARB Bull Bar with Piaa 520 drivings, no winch yet though Kenwood Headunit, Kenwood Sirius Reciever, RF Punch p2002 Amp, RF Punch 10" Sub enclosure Hypertech power programmer K&N 77 series FIPK Flowmaster 50 SUV Magnaflow Cat next gears and lsd's and OME coils[/SIZE] [CENTER][COLOR=Green]Colorado Jeep Club Member #14[/COLOR][/CENTER] [COLOR=White][CENTER]White Jeep Club Member #114[/CENTER][/COLOR] |
#10 |
I'll agree with the weather tecs.....they are the best!Had them on two prior vehicles, much better then any tape on's!! Spend the cash and never worry about them again.
Mark in Kentucky 93 YJ 4cyl 5 spd 4" RC Lift, 33x12.50 MT's |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
