Window Regulator Plastic Piece ???? - JeepForum.com
post #1 of 7 Old 05-31-2009, 09:50 AM Thread Starter
CheapSunglasses
2007 XK Commander
I'm a regular over on the YJ forum with my '89, and this is the first time posting here for my wifes '01 GC....
I have an issue with the driver side window regulator and with some pix and the best description I can muster, I hope someone can help me out....
There are what looks like two plastic pieces (maybe one) at the bottom of the track that the window slides up and down on that houses the sheath of the window cable and also acts as a guide for the wire (shaped like a half moon)....Those pieces snapped off and I would like to know what exactly they are called, and if are they available independently from the regulator itself....I was told by a garage (a tricky garage) that you need to buy a whole new regulator....All help is appreciated.
Thanks in advance
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #2 of 7 Old 05-31-2009, 10:21 AM
steelstr45
I'm not sure what they're called, but I believe the official repair is to replace the entire regulator. Check out this thread, someone fixed theirs with a part from Lowes.
http://jeepforum.com/forum/showthread.php?t=177859
steelstr45 is offline
post #3 of 7 Old 05-31-2009, 10:30 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Keep searching (I don't have the link handy) but there is an aftermarket metal piece you can replace the broken plastic piece with that fixes the weak link. They're like $25 I believe.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #4 of 7 Old 05-31-2009, 11:02 AM
iluvtruenos
Autozone's replacement is all-metal for $72.99, and has a lifetime warranty. Complain about something (non-cleanliness of the store or something) and they'll knock 10% off.
iluvtruenos is offline
post #5 of 7 Old 05-31-2009, 05:31 PM Thread Starter
CheapSunglasses
2007 XK Commander
I fixed the plastic piece....I drilled a hole through it and mounted it with a little nut and bolt....Done!
Now for the new issue....The cables that control the window somehow got all jambed up in the plastic winding....If you've ever seen one, it's wound in two different directions like a weed whacker....Well, the cables and the plastic housing that attaches to the motor are SHOT....Do I have to buy the motor or can I just buy the housing and the cables?
post #6 of 7 Old 05-31-2009, 06:28 PM
iluvtruenos
It' shot, sorry. I know exactly what you're talking about, and as a matter of fact, I've had the exact same issue. the metal cable gets all bent out of shape, and it's nearly impossible to rewind it properly. Get a new setup, Vatozone sells 'em, and I've got a spare OEM that you can probably have for $50.
post #7 of 7 Old 06-02-2009, 11:05 AM Thread Starter
CheapSunglasses
2007 XK Commander
Thanks....Check your PM.
plastic piece for window wire broke? shesajeep ZJ Grand Cherokee Forum 3 10-01-2009 07:33 PM
baffle/plastic piece inside airbox.... NoLimitsLimited ZJ Grand Cherokee Forum 4 01-17-2006 12:04 PM
That stupid plastic piece on top of engine ///BHRpowered ZJ Grand Cherokee Forum 10 10-28-2005 06:40 PM
Window Regulator plastic busted rblue98 ZJ Grand Cherokee Forum 5 10-26-2005 12:58 AM
Detaching window glass from '02 window regulator? dotspace ZJ Grand Cherokee Forum 3 08-04-2005 07:23 PM
