window problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > window problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 02-05-2008, 02:28 PM   #1
rmtomasin
window problem
i'm getting some mixed messages about how to fix the windows. i checked the faq and read peoples recent posts and i'm not really sure what to do any more. my rear windows wont role down from the rear door controls but they will form the driver control, thats a problem with the wiring in the door boot or is it a motor problem?
-Ryan-
Built Not Bought #233
98 ZJ I6
Build Thread
rmtomasin is offline   Reply With Quote
Unread 02-05-2008, 03:27 PM   #2
GraKee99
Rapist Wit
GraKee99's Avatar
That sounds like it would be a wiring issue since they can roll down from the driver control. If they wouldn't roll down from the any of the switches, it would be the motors.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote
Unread 02-05-2008, 03:28 PM   #3
UofOJeeper
sorry if i am pointing out the obvious, but did you check to see if window lock was on?
1998 Laredo Special Edition V8
Toyo Open Country A/Ts - 245/70/R16
242 Swap
"A man who asks no questions, rarely has any answers"
UofOJeeper is offline   Reply With Quote
Unread 02-05-2008, 03:31 PM   #4
rmtomasin
no it wasn't it has been like this for like 6 months, i've been meaning to fix it but now i'm just getting to it.
edit: the pasenger window rolls down form that control so it's not stuck or anything either
-Ryan-
98 ZJ I6
Build Thread
Unread 02-05-2008, 07:21 PM   #5
alivenkickin28
THAT IS NOT A WIRING ISSUE!!! you either have a bad switch on the individual door itself or your master control is shot....My 93 Grand Cherokee Limited had to have all the switches replaced as they j ust started to go one by one and finally the master control....same symptoms you're having...save your self the trouble its not the wiring...
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
[url]http://s221.photobucket.com/albums/dd197/alivenkickin28/[/url]
alivenkickin28 is offline   Reply With Quote
Unread 02-07-2008, 10:51 AM   #6
thetoughguy
I have to tend to agree with this. In my experience, it is hardly ever a "wiring issue". Unless someone is doing something with the electrical system and damages a wire that ends up shorting something out, the wiring usually won't be the problem. That's not to say it doesn't happen, but I would say the actual wiring would be one of the last things to check.
thetoughguy is offline   Reply With Quote
Unread 02-07-2008, 11:26 AM   #7
driabyor
1994 ZJ
10 charactors
Originally Posted by driabyor View Post
this is a picture of the wiring harness. the one with the connector is to the rear window. It broke again , so my guess is a butt connector isn't the best fix... I think next time I will solder about 1/4" ,then heat shrink it... as for the rest I think I will try Liquid Tape..
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline   Reply With Quote
Unread 02-08-2008, 09:34 AM   #8
bigred_topher
i replaced the wiring between the door and the cab because the wires had broken and now i've only got control of my drivers side windows... the pass. side will roll down but not up and the rear pass. won't do anything at all... so i'm taking the damn doors off and not messing with it any more!!!!! but seriously what is my issue.. am i stupid or what the hell is the problem???
SOLD 95 ZJ, 7.5" Rustys, custom LA's, 35's, HP30, Ford 9" Posi Trac, 4.56f&r, custom f&r bumpers, 231 TC, CAI, TB spacer, flowmaster 50 series, adjustible front tracbar, rustys steering conversion[/COLOR]
Red Jeep Club Member #458
bigred_topher is offline   Reply With Quote
Unread 02-08-2008, 06:33 PM   #9
alivenkickin28
you could have bad switches....my 93 started one by one and started with the front pass side, then made itself around til the master finally went...when this happens guys its more often a switch than it is wiring...im sure that wiring sometimes breaks but check the switches and motors first....
Unread 02-09-2008, 05:19 AM   #10
rmtomasin
would you say that it is the individual switches or the master/ window lock is messed up?
-Ryan-
98 ZJ I6
Build Thread
Unread 02-11-2008, 12:41 PM   #11
bigred_topher
ok so magically this weekend my windows started working.... all but one... i'm satisfied and i can get some fresh air now... but i would like to get hem all to go down and not have to worry about it...either way the doors are coming off when it gets a little warmer and i won't have to deal with it anymore!!! (i'm gonna check the switch also and see if that fixes it and if it does then you guys rock!!)
Unread 02-11-2008, 05:47 PM   #12
alivenkickin28
ohhhhhh so you could hve other issues if you're taking doors on and off...i didnt realize that....
Unread 02-24-2008, 09:36 PM   #13
thetoughguy
i actually had this problem with my 2000 gc. the windows actuators were shot. they would work one day and then not work for weeks at a time. apparently this is an issue many gc owners have had. I didn't think of this the first time i read your post though, until you wrote they "magically" started working again. It was awhile ago, so I think it was the actuators, not a cheap fix either.
