window issues - JeepForum.com
post #1 of 10 Old 05-11-2013, 08:14 PM Thread Starter
zeak411
window issues
my drivers door window on 1995 zj i had down for most of the day and went to go roll it back up did not go up idk if it could be master switch but all the other windows can be controlled with the master switch how would i go about testing the master switch dont have test light and also how would i get to the window mottor and how would test to see if its bad when i press up on the switch i dose not make a single sound please help soon thank you
zeak411 is offline
post #2 of 10 Old 05-11-2013, 08:26 PM
JasonStebbins
Pull out the wiring bundle inside the boot when the door is open. Most likely a broken wire.
Poop
JasonStebbins is offline
post #3 of 10 Old 05-11-2013, 09:13 PM Thread Starter
zeak411
wait how would i do this and how would i check it
zeak411 is offline
post #4 of 10 Old 05-11-2013, 09:14 PM Thread Starter
zeak411
how would i do this and how would i check it to see if there bad little confused
zeak411 is offline
post #5 of 10 Old 05-11-2013, 09:33 PM Thread Starter
zeak411
no its not all wires look good to me would you now how to check if the switch is bad
zeak411 is offline
post #6 of 10 Old 05-11-2013, 10:36 PM
JasonStebbins
Was the window working perfect before it died or did it seem like the motor was failing? From my experience and here on the forum, it's usually a broken wire in the bundle. Did you pull them out as far as you could?
You need a voltmeter to check continuity of the wiring that connects to the back of the master switch.
Also swap one of the large fuses in the fuse panel that controls them. Didn't notice it was a 1995. My 1993 did this, the large silver fuse blew out that controlled the windows.
Poop
post #7 of 10 Old 05-12-2013, 12:48 AM
KoreaZJ
1994 ZJ
All other windows work, so fuses and door boot wiring (+12v and GND) should be good. All windows use the same +12v/GND in the driver door switch.
That leaves... driver door window switch UP position is bad, or window motor won't reverse. Either way, door panel needs to come off to isolate the problem.
Unplug the window motor connector. Check for +12v and GND between the two pins from the switch (WT & LB wires). With switch in DN position, should measure +12v and GND (WT & LB). With switch in UP position, +12v and GND should flip to the opposite wires (LB & WT).
If switch tests good, then likely bad motor. Motor can be briefly hooked directly to +12v source for testing. Reverse the wires, motor should reverse.
KoreaZJ is offline
post #8 of 10 Old 05-12-2013, 01:17 AM
JasonStebbins
You know too much about electrical KZJ.
Poop
post #9 of 10 Old 05-12-2013, 08:31 AM
dusterdude
Damn glad he does
dusterdude is offline
post #10 of 10 Old 05-12-2013, 09:44 AM
KoreaZJ
1994 ZJ
KoreaZJ is offline
door , switches , window
