Window help please? - JeepForum.com
post #1 of 5 Old 04-17-2013, 08:33 AM Thread Starter
Trojans43
Window help please?
Overnight my windows have ceased to function? All windows apart from passenger front (RHD) fail to operate.
Drivers door pod will also not operate any window, window lock does not operate, Door lock does, drivers mirror does passenger not. Memory position can be set, 1&2 but fails to be memorised?
All functions on passenger pod are operating as normal
Trojans43 is offline
post #2 of 5 Old 04-17-2013, 08:44 AM
Wavedatya
2010 JK Wrangler
Try checking to see if connections under window control panel are connected. You should just be able to lift it up and have enough slack from all the wires.
Did it get wet?
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #3 of 5 Old 04-17-2013, 12:16 PM Thread Starter
Trojans43
Have had door card off, all connections are good! Not got wet at all?
post #4 of 5 Old 04-17-2013, 12:22 PM Thread Starter
Trojans43
Remote Key-fob locks all doors apart from drivers - passenger door lock switch locks all but driver's, Driver's switch only locks drivers door- No others! immobiliser works and needs fob to enable engine??
post #5 of 5 Old 04-18-2013, 06:21 AM Thread Starter
Trojans43
Weird! Panic over, It all just started working again! But haven't done anything to it!
(scratching head)
Not knocking it though lol.
