Window cable slipped off track 2000 Grand Cherokee Larado - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Window cable slipped off track 2000 Grand Cherokee Larado
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits End of Summer Sale, 20% OFF!
Unread 09-05-2014, 08:53 AM   #1
shula
My front driver side was hit by another car and damaged my front driver side fender. My auto window does not go up or down but the motor still works. I removed the regulator and saw that one end of the cable had been dislodged form the plastic piece. I got the two cable ends back into the correct slots, but when I try to run the cable over the end plastic track, the cable is about 1/2" to short? I tried hooking the window motor back up and rolling all the way up and then all the way down, but could get not more cable out of it. Can anyone tell me the trick to get more cable out of it so I can wrap it round the end plastic track piece? Thanks
shula is offline   Reply With Quote
Unread 09-05-2014, 09:37 AM   #2
vlackattack
This forum's for 93-98 Grand Cherokees. This forum would probably be more helpful: http://www.jeepforum.com/forum/f310/
vlackattack is offline   Reply With Quote
Unread 09-05-2014, 11:44 AM   #3
KJK
I believe you need to compress the springs on the cable housing to get enough slack to pull the cable over the end. Probably need 4 hands to do this so find a good helper.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline   Reply With Quote
Unread 09-05-2014, 07:12 PM   #4
coralman
green backs to no backs
coralman's Avatar
There is a video on you tube from start to finish.
Move over bear.I'm tired of working on the jeep
Links to axle rebuilds, mount replace,a/c box rebuild,ect in history section of my profile page
coralman is offline   Reply With Quote
