Will zero oil pressure = Limp Mode? - JeepForum.com
post #1 of 7 Old 09-24-2009, 09:40 AM Thread Starter
PT's93
'97 ZJ, 4.0
Oil pressure gauge reads zero. Coolant temp normal, Engine runs fine for a few minutes, then looses power & 35mph becomes top speed. No ticking or knocking.
Will zero oil pressure indicated put the engine into Limp Mode after a period of time?
This is brother-in-law's ZJ. He noticed lack of oil pressure after third power loss (he was assuming tranny problems). Three power losses in a three day period, and still no ticking, knocking, or running hot. Before I start looking at the oil pump and its drive, wondering if all it needs is a sending unit.
Thanks!
1998 ZJ Limited 5.2 ** 1996 Explorer Limited 5.0 ** 1882 Honda GL500 ** 1993 XJ Sport (R.I.P.)
PT's93 is offline
post #2 of 7 Old 09-24-2009, 10:28 AM
greasefingers
greasefingers's Avatar
1994 ZJ
No neither the PCM nor the TCM get readings from the oil pressure sensor. It only goes to the dash board gauge.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 7 Old 09-24-2009, 10:59 AM Thread Starter
PT's93
Thanks!!
I was afraid of that.
Yet, one of the computers knows that there's something wrong. Brother-in-law reported that a "Check ???" light was flashing on last run. I'll pull the ScanGauge out of my Explorer and check his codes before yanking the pan off. I'll also check for a broken pump drive shaft. Can you tell that I'm not looking forward to taking the oil pan off!
Thanks Again!
PT's93 is offline
post #4 of 7 Old 09-24-2009, 02:37 PM
acidspit86
i dont know about the zj but on the wj it wont bring you down to limp mode
acidspit86 is offline
post #5 of 7 Old 09-26-2009, 10:49 AM
Kota04SXT
2006 WK
Flashing CEL is no good. Usually indicates a knock/bad miss in a cylinder. Does the oil pressure gauge move when he gives it gas?
2013 Ram Express QC 4x4
2006 WK
Kota04SXT is offline
post #6 of 7 Old 09-26-2009, 05:17 PM Thread Starter
PT's93
Talked to brother-in-law - It was a "Service Engine Soon" light on the Information Center, not a CEL. They probably didn't do a reset at last oil change.
Do not know about pressure rise on rev-up. I'm going to wait till he gets it to my place for further diagnosis (the only in-law that's mechanically inclined was the father & now that he's passed away I seem to have been voted the family mechanic).
PT's93 is offline
post #7 of 7 Old 09-26-2009, 06:47 PM
simidrm
limp mode
I would say that your oil pressure sending unit has gone bad because if you had 0 oil pressure that engine would self destruct in less than a min,as far as limp mode that is a transmission issue where when the gov pressure sensor goes bad the tranny goes into limp mode which will usually only give you 3rd 4th and over drive and starting out in 3rd gear will make the engine work hard to get moving resulting in slow speed until rpm get up to normal range this is a protection for the tranny that also lets you get vehicle to a service station.
simidrm is offline
94 zj limp mode cheapmf ZJ Grand Cherokee Forum 2 09-19-2008 03:06 PM
94 Jeep GC in limp mode COAV8R ZJ Grand Cherokee Forum 0 06-10-2008 12:20 PM
42re limp mode again jbigalow ZJ Grand Cherokee Forum 7 08-06-2007 10:14 AM
Limp mode MotoX5874 ZJ Grand Cherokee Forum 1 06-28-2007 12:31 PM
limp mode jbigalow ZJ Grand Cherokee Forum 3 01-15-2007 05:39 PM
