will a y link radius arm work - JeepForum.com
post #1 of 12 Old 08-22-2009, 07:55 PM Thread Starter
ghudson434
I have a 93 grand and planning on building a "y" link radius arm setup for the front. I was wondering if this same set up would work for the rear. I am a newbie and have searched and cant find this topic for a zj but have seen it on a tj i believe. I have a 2 in budget boost but im planning on a fr to rear swap before i do this build.
ghudson434 is offline
post #2 of 12 Old 08-22-2009, 08:19 PM
sandman
your best bet for the rear is to triangulate the upper arms and eliminate the track bar. hop over on mallcrawlin and brouse through their members rigs section most of those guys have custom LA set ups.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 12 Old 08-22-2009, 08:30 PM Thread Starter
ghudson434
read some about that and that seems a little complex. but i will check that out. seen alot of figureing out geometry stuff but ill read up some more on it.
post #4 of 12 Old 08-22-2009, 09:22 PM
FortCollinsZJ
A double triangulated or single triangulated four link is much easier to make it work, there is just som many builds to get ideas from.
That being said, if you do a radious arm setup in the rear, you will have a trackbar, unless you triangulate the radious arms, which is a possibility. I would suggest a double triangulated setup if you can do it.
FortCollinsZJ is offline
post #5 of 12 Old 08-22-2009, 09:53 PM Thread Starter
ghudson434
where would i need to start in designing the triangulated 4 link and would i also need to design the y link for the front or is it as easy as it looks? i mean as far as just makeing the cross member and the control arm brackets and the control arms? or is it certain angle that the arms need to be in relation to say flat ground that i need to know to build these? maybe im wrong but yes they both look simple but i see the chart with axle squat and stuff like that and its kinda confuseing me. im not really looking for huge amounts of articulation just looking to make the ride more comfortable when i go higher with the lift.
post #6 of 12 Old 08-22-2009, 09:54 PM
StrokedWJ
StrokedWJ's Avatar
Radius arms do not work well in the rear. Your anti-squat #'s will be horrendous.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #7 of 12 Old 08-22-2009, 09:59 PM Thread Starter
ghudson434
what do i need to know before i start building this thing? i know how to read and am willing to do it. just let me know what to read or point me in a direction for someone just learning.
post #8 of 12 Old 08-23-2009, 08:36 AM
StrokedWJ
StrokedWJ's Avatar
Google 4-link rear suspension. Theres a **** ton of reading out there to do. I think 4wd magazine had a recent article that touched on the basics of rear suspension design.
Go to Pirate4x4.com and Mallcrawlin.com and do some more research & reading. Then, once you understand the basic principles, get under your rig with a tape measure and a 4-link calculator and start laying out a design. You'll most likely have to make some trade offs between the best setup in the calculator and what actually fits on your jeep.
post #9 of 12 Old 08-23-2009, 11:44 AM
FortCollinsZJ
Ok some quick rules of thumb.
Upper arms, should be 70% of the length of the lower arms, give or take.
Mount the uppers on the axle above the differential, and the lowers flush with the tube. The seperation between the links at the body end should be half the measurment of the axle end, IE lower link to upper link on the axle end could be 10", the body should be close to 5" seperation height wise, if that makes sense.
It is best to mount the ends of the lowers as wide as possible on the axle, it creats stability and flexes better, just watch out for tire clearance. The angle of the tabs on the upper axle truss ideally is 22.5 degrees, same for the body side lower tabs if making a double triangulated 4 link.
post #10 of 12 Old 08-23-2009, 05:35 PM Thread Starter
ghudson434
well im more lost than i was before i started reading guess i should just buy a kit from somewhere that has all the angles and lengths already figured out. way over my head. thanks guys.
post #11 of 12 Old 08-23-2009, 07:53 PM
FortCollinsZJ
NO! I say build not buy! If you have the ability to read, and a welder, or access to one, you can save yourself a ton of money. I am building my entire rear suspension for under 350.00! probably less!
Just read and read some more, about a week of research for an hour or two a night, and you should have enough info to at least start a build.
post #12 of 12 Old 08-23-2009, 08:01 PM
FortCollinsZJ
Ok, this link is to a tracker build, but litterally the same principal, granted this guy is wicked good at fabbing, but I just really like how he shows so many detailed pics.
Kelsey's DD tracker - Page 2 - MallCrawlin.com Forums
Here is a good picture to show you a double triangulated rear four link.
Converting radius arms to 3-link StrokedWJ ZJ Grand Cherokee Forum 3 12-26-2009 09:43 PM
Front Radius Arms -- Johnny joints or bushings StrokedWJ ZJ Grand Cherokee Forum 10 08-11-2009 12:50 PM
groaning while turning in small radius cloiselle ZJ Grand Cherokee Forum 4 03-05-2009 09:57 PM
bent radius arm bracket???? rallyjeep_11 ZJ Grand Cherokee Forum 3 02-17-2009 06:10 PM
tie rod ends + Drag link ends....will this work?? -cAcHe- ZJ Grand Cherokee Forum 10 07-03-2008 02:52 PM
