Will using 4low on pavement hurt the vehicle? - JeepForum.com
post #1 of 16 Old 09-12-2010, 08:03 PM Thread Starter
TCarbo20
Will it damage the vehicle?
TCarbo20 is offline
post #2 of 16 Old 09-12-2010, 08:04 PM
TowMaster
Yes. Don't do it.
NightCrew #125
Why don't they have braille at drive-thru's?
TowMaster is offline
post #3 of 16 Old 09-12-2010, 08:20 PM
comptiger5000
It's ok with a 93-95 249, but with a 96-98 249 or any other t-case, the driveshafts are locked in 4lo, and bad stuff will happen. As towmaster said, "don't do it".
comptiger5000 is offline
post #4 of 16 Old 09-12-2010, 08:44 PM
JesseOR
Originally Posted by TowMaster View Post
Yes. Don't do it.
You run it on dry pavement AS LONG AS you do NOT make ANY turns. Soooooooo.........don't do it...
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #5 of 16 Old 09-12-2010, 09:27 PM
EBT531
Actual pavement bad idea. But areas like Moab I see guys run lockers in 4LO most of the day (very slowly) and it seems to work
1998 5.9ZJ, 231 TC w/SYE, IRO 4.5" Lift, IRO Adjustable CA's, Bilstien shocks, IRO Sliders, MVC Truss Rear, High Angle Driveline Front and rear shafts, 4.56 gears
EBT531 is offline
post #6 of 16 Old 09-12-2010, 09:51 PM
Ganjatrooper
1994 ZJ
why is 4lo on pavement bad? I know what 4lo is but i didnt know it on pavement would be bad? but why would you need 4lo on pavement
Ganjatrooper is offline
post #7 of 16 Old 09-12-2010, 10:01 PM
freakinheep89
4 lo on pavement on any other case besides the 93-95 249's is bad because the case locks the front and rear outputs, in a turn, the front wheels need to spin faster than the rears, the case will not allow it and stuff starts to bind and break. the reason you can use it off road is that when you take a turn, the rear tires just spin on the dirt or whatever. pavement does not allow the tires to spin to keep up with the front
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #8 of 16 Old 09-13-2010, 11:00 AM
TowMaster
I did indeed forget the exception there, that is my mistake. But I will still suggest even in those not to do it, just as a general practice so it isn't forgotten. I think the only time someone would need 4lo on pavement is for the gear reduction to pull something very heavy that the vehicle can't handle in 2hi/4hi/4PT/etc. That said, that's a terrible idea for several reasons. One, its obivously too much for the vehicle to handle, use something designed for it, and you couldnt go more than what...20mph? Even just to pull a big trailer across a parking lot is a bad idea, becuase it's pavement. I got lazy once and didn't feel like getting the truck so threw the ZJ in 4lo to pull my boat across the yard. I was on dirt so that was ok, but it was still a DUMB idea, because the Jeep sin't designed for that. followin us?
NightCrew #125
post #9 of 16 Old 09-13-2010, 11:06 AM
Reswob
As long as you don't turn or go over 25mph it wouldn't hurt anything.
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #10 of 16 Old 09-13-2010, 12:36 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
only time 4lo should be used on pavement is pulling a boat out of a launch.
ratmonkey is offline
post #11 of 16 Old 09-13-2010, 07:32 PM Thread Starter
TCarbo20
thanks guys i was told about the front wheels spinnnin faster and i wanted to make sure if i needed to pull a boat outta a mud boat ramp to use the 4lo i know to never use it on cement but i was just curious, gotta protect my 5.9 )
TCarbo20 is offline
post #12 of 16 Old 09-13-2010, 07:42 PM
TowMaster
I would think on a muddy boat launch you would be just fine, the wet cement would be slippery enough I would think, just disengage asap. But then again, that 5.9 should be fine as long as the tongue on your trailer is long enough.
NightCrew #125
post #13 of 16 Old 09-13-2010, 07:58 PM Thread Starter
TCarbo20
no, no cement straight gulf florida mud on low tide. to pull a 6,000 boat out.
TCarbo20 is offline
post #14 of 16 Old 09-13-2010, 08:10 PM
Candymancan
What about running 4WD Full time like on a 242 transfer case ? On pavement
Candymancan is offline
post #15 of 16 Old 09-13-2010, 08:29 PM
freakinheep89
its designed to run on pavement. thats why there are separate options 4ft is for on road, and 4pt HI is for off road.
TJ-
Grinding in 4LOW wolfman65 ZJ Grand Cherokee Forum 17 10-29-2012 02:51 PM
ID XK 4Low pd- WK Grand Cherokee & XK Commander Forum 3 06-15-2010 12:36 PM
'97 ZJ LTD shifting into 4LOW richiscool ZJ Grand Cherokee Forum 12 02-26-2009 02:54 PM
some 4LOW questions.. lakailimited06 ZJ Grand Cherokee Forum 5 08-01-2008 06:29 PM
4low lock? rJEEP ZJ Grand Cherokee Forum 5 01-29-2003 04:56 PM
