Will TJ coils fit on A ZJ? - JeepForum.com
post #1 of 12 Old 04-18-2010, 01:13 AM Thread Starter
FST1994ZJ
1994 ZJ
I have 2 inch coils right now on my ZJ. There is a set of 3.5 inch TJ coils on craislist wondering if they would fit?
5.2 eating up the streets :D
FST1994ZJ is offline
post #2 of 12 Old 04-18-2010, 01:15 AM
bigb229
i think theyll go on the front...but im not sure about the back. some guy used v8 tj coils on the front of his tj...hes trying to sell them now...but i think the tj rear springs are a lot bigger diameter wise.
bigb229 is offline
post #3 of 12 Old 04-18-2010, 01:23 AM
newfieZJ
Only going to give you 1/2 inch over what you have now
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #4 of 12 Old 04-18-2010, 01:24 AM Thread Starter
FST1994ZJ
1994 ZJ
why will it only give me a half an inch?
post #5 of 12 Old 04-18-2010, 01:25 AM
newfieZJ
TJ's are lighter , you'll loose 1 inch for sure with the V8 . I know , I run TJ springs
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #6 of 12 Old 04-18-2010, 01:30 AM Thread Starter
FST1994ZJ
1994 ZJ
oh ok. thanks. i have 2 inch coil spacers and 2 inch springs. what can i do to get more lift?
post #7 of 12 Old 04-18-2010, 01:36 AM
newfieZJ
to get higher than you are will require alot of money . I'm going from 4.5 to 7" , for an additional cost of almost $2000 not including bigger tires , I already have frt LA"S .
Sure you want to go there ?
I'd just get some new 4.5 springs and ditch the spacers
newfieZJ is offline
post #8 of 12 Old 04-18-2010, 08:08 AM
tonyp6796
also using tj springs it makes it a really stiff ride.
1996 zj 5.2, 7" IRO LA's, IRO OTK steering, 8.8 rear end, 33 bfg km2's, 231 TC.
tonyp6796 is offline
post #9 of 12 Old 04-20-2010, 10:22 AM
PaLftr
How much lift will 4.5" TJ coils give on an inline 6 ZJ?
ZJ DD, WW. 4.go litre modded. 3", 31's. Needs armor.
PaLftr is offline
post #10 of 12 Old 07-25-2011, 07:23 PM
CTeunuch
Back from the dead, but anyone have an answer for this?
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
CTeunuch is offline
post #11 of 12 Old 07-25-2011, 07:27 PM
tonyp6796
It should give you 4.5" cause the motor weighs the same. I hate having tj coils under my 5.2 Zj. The ride is stiff as hell and the coils bounce off the front bumpstops.
post #12 of 12 Old 07-25-2011, 11:34 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The tj is a lot lighter than the zj, you lose 1.5 –2" of lift under a zj.
It feels stiffer because the coils are nearly sitting on top of eachother.
ratmonkey is offline
bought IRO 3.5 lift and just received them but the coils say xj 4.5 coils will they.. stiller ZJ Grand Cherokee Forum 4 12-06-2008 12:02 PM
XJ coils on a ZJ? Tiggerrrrr ZJ Grand Cherokee Forum 6 11-05-2008 12:39 PM
Zj coils XJeepness ZJ Grand Cherokee Forum 2 07-28-2005 07:07 PM
V8 coils for ARB? 01grander ZJ Grand Cherokee Forum 1 06-30-2005 12:46 PM
V-8 coils XJeepness ZJ Grand Cherokee Forum 2 06-27-2005 07:44 AM
