Will these tires fit? - JeepForum.com
post #1 of 18 Old 06-17-2011, 10:42 AM Thread Starter
nothinlikeaJeep
My jeep has no lift and I am thinking about getting new tires. I found a great deal on craigslist and I want to get them but I want to know if they're going to fit. They are 31x10.5.
nothinlikeaJeep is offline
post #2 of 18 Old 06-17-2011, 10:50 AM
JeepNaked9969
I run 32s on a stock 06 tj sport, but they do rub a bit, even after i trimmed the fenders. Thats with sway bars off at full flex. If you do mild wheeling, or no wheeling at all, 31s, in my opinion, should work just fine. If you dont like em, trade down or put em back on craigslist...... also, something i do when i need tires is just order 1 tire at a time offline. Discounttiredirect.com had free shipping at the time i purchased mine earlier this year.
Also, i have backspaced wheels (3.5", i believe). I dont rub on turns, not sure if 31s will rub on stock rims, i would imagine not.... but its possible. One of the veterans of the wide world of jeepers should have a definitive answer for ya..... just thought id share my thoughts! :-)
JeepNaked9969 is offline
post #3 of 18 Old 06-17-2011, 01:21 PM
speedbucket
stick to the open top jeep side of the forum before you cost someone money. this is the ZJ section of the forum
they will be super tight, you will have to trim ALOT and will have zero suspension travel
this is straight from the FAQs, i reccommend you read all of the FAQ sticky
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #4 of 18 Old 06-17-2011, 03:25 PM Thread Starter
nothinlikeaJeep
ok I had a feeling they would be tight. But would they be drivable without any modifying or no?
post #5 of 18 Old 06-17-2011, 03:33 PM
speedbucket
What do you mean by modifying? You need a sawzall and bfh to make them fit. And alot of it
post #6 of 18 Old 06-18-2011, 10:22 AM
JeepNaked9969
I apologize for that! I didnt notice when i was on my phone. I would not have chimed in at all had that been obvious to me.
BUT. no need to be a little snot about it. and money for what? tires? F IT! give it a shot. whether or not its an open top JEEP or not, JEEPS are FUN! Do what you want, learn from your mistakes! The only way to learn to swim is by jumpin in the water!
post #7 of 18 Old 06-18-2011, 11:09 AM
Foundrydude
I recently had a zj in the driveway with 31x10.5s on stock rims, no lift. Owner claimed they didn't rub and fit fine, but my eyeball disagreed. It was a commuter jeep, and he'd worn 3/4 of the tread off, so they obviously fit good enough to drive even if they must've rubbed like h*ll when corners and bumps were combined.
The other factor is ZJ gained around 400lbs in 1996 and springs did not change. Between that and spring wear, some jeeps sit as low as station wagons.
A go for broke, learn from your mistakes method ^ is not the way to buy tires unless you like buying two sets, or living with wrong size tires for years at a time. It's much better to do your research, do some measuring, look at other ZJs, and buy the right set the first time.
An inch of rim width or backspace is everything, so know what people are using if you're taking recommendations. There's also variation between tire brands, with cheap tires tending to run small and quality boggers tending to run big. Also, guys with ribbons of rubber torn out of their sidewalls from body interference will look you in the eye and tell ya those tires fit. (That's guy's my best friend, say hi if you see him) Use common sense and you'll be fine.
If you're willing to buy a full set and work with the shop's schedule, they'll often mount one tire to help you make a size decision on the day of install.
Good luck.
Foundrydude is offline
post #8 of 18 Old 06-18-2011, 11:21 AM
taz95zj
I have a 95 ZJ with 31x10.5 pegasus avants AT and no lift it rubs at steering lock and that's it and as for suspension travel it suffers with out the lift but It still is capable my advise would be if you can afford it get a 2" BB. I have one but haven't had time to install it. anyway they will fit but it's snug and you just have to be carful in parking lots
taz95zj is offline
post #9 of 18 Old 06-19-2011, 09:05 AM
tcar
I have a 94 with the UpCountry suspension.
Have 29's and had to trim a bit of the bottom of the plastic bumper. Not visible.
31's?
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
post #10 of 18 Old 06-19-2011, 09:24 AM
Foundrydude
235/75-15s are 29" tall and half this board runs em on unlifted jeeps. I think it's what upcountry came with.
I'll go back to tire width, rim width, & backspace being key to this discussion. With old-skool reverse offset mags stock tires will rub. Is it so suprising nobody agrees on what fits when one huge variable is ignored?
post #11 of 18 Old 06-19-2011, 07:06 PM
Derph
1994 ZJ
^ big Lolz. I have 235/75 R15 and they measure about 28". Stock rims(98 Xj) and just the slightest rub at full lock. I'm not concerned about the rub. My bad 249 has fixed that problem for me.
Derph is offline
post #12 of 18 Old 07-17-2011, 12:29 AM
taz95zj
i agree on what I personally experienced lol 31x10.50r15 fit on my 95 Canadian spec ZJ no lift with rub at steering lock with stock rims. still good amount of flex but yes rims with less backspace and my BB will negate any issues with fitment
taz95zj is offline
post #13 of 18 Old 07-17-2011, 12:32 AM
Black97ZJ
My uncle had a set of 31x10.5s on his stock rims with no lift and they only rubbed at full turn. He didn't trim the bumper or anything
Black97ZJ is offline
post #14 of 18 Old 07-17-2011, 01:13 AM
JohnnyZJ
drive over a steep curb or speedbump at full turn; you'll disagree with 31s 'fitting'
many people, some on this board, rub their 31s BAD with a 3.5" lift and 31s. all depends what you do; if you have a bad tcase and upcountry suspension, you can run 31s on the street! been there, done it. used to rub pulling into the driveway though.
guess it depends on what your definition of 'fit' is. if they rub at any point on the street, it will be hell on the trail.
if you bought a 2011 jeep and your tires rubbed at full lock i bet you would disagree that your tires 'fit'
07' JKUR rollin on 35s
JohnnyZJ is offline
post #15 of 18 Old 07-17-2011, 03:01 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I ran 245/75/16 mtrs for a bit while stock. Fit is the furthest thing from my mind when describing them.
Most people have a very liberal view of fitment and will accept rubbing on the control arms, sway bar, bumper fascia, and fender just because they like the bigger tires.
These guys fitting larger than 30" tires on stock leave the evidence of their proper install all over the outer lugs of their tires
ratmonkey is offline
Need new tires...current tires too big? goldenarms ZJ Grand Cherokee Forum 6 08-13-2008 07:45 PM
Tires Mud Or A/T '93Jeep ZJ Grand Cherokee Forum 13 02-07-2008 04:46 PM
BB and Tires augnmike ZJ Grand Cherokee Forum 8 02-06-2008 04:09 PM
Poll. tires with rims, or tires with lift. Derek33 ZJ Grand Cherokee Forum 2 03-15-2005 05:43 PM
New tires for 97 GC Tomd ZJ Grand Cherokee Forum 7 07-21-2004 06:52 PM
