Will shocks from 89YJ with 4"lift fit 95 Grand with 2" lift? - JeepForum.com
post #1 of 10 Old 04-04-2009, 11:42 PM Thread Starter
bunk1967
So, will procomp mx6 adjustable shocks that came off of a 1989 YJ bolt onto a 1995 Grand Cherokee? The YJ has a 4" suspension lift, the Grand Cherokee has a factory 2" lift. It's the orvis edition. Any help on this would be great.
bunk1967 is offline
post #2 of 10 Old 04-04-2009, 11:45 PM
Virmagicus
Virmagicus's Avatar
How many pancakes does it take to shingle a doghouse ? Welcome to GD Try the Grand Cherokee Tech forum.
Jeff
Virmagicus is offline
post #3 of 10 Old 04-04-2009, 11:51 PM Thread Starter
bunk1967
LOL, Sorry I thought I was.
bunk1967 is offline
post #4 of 10 Old 04-04-2009, 11:52 PM
Virmagicus
Virmagicus's Avatar
G/L
Jeff
post #5 of 10 Old 04-05-2009, 01:41 AM
RrCoX22
a shock is a shock... it will work but unsure about the damper rate. if they're adjustable all the better
1997 5.2L ZJ Limited
RrCoX22 is offline
post #6 of 10 Old 04-05-2009, 04:32 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
That is not true. Some shocks have different fittings causing them not to work on different models. Not all Grands like mine have the shock loop adapters installed, therefore they need the front shocks to have the bayonette fittings to work.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 10 Old 04-05-2009, 10:11 AM
4jeepers
The shocks may want to bottom out when going over bumps! I would check with someone like Quadratec.com. They have a lot of useful information on suspension questions!
4jeepers is offline
post #8 of 10 Old 04-05-2009, 11:35 AM
Greengc4x4
measure them.....
Greengc4x4 is offline
post #9 of 10 Old 04-05-2009, 12:15 PM
RrCoX22
normally shock companies will give you supplied parts to accomadate different vehicles... the shocks on my vette, camaro, and grand cherokee would all be interchangable... you just have to adapt with bushings, etc.
RrCoX22 is offline
post #10 of 10 Old 04-05-2009, 12:21 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Stock YJ shocks are eye/stem front and eye/eye rear.
Not sure about the length.
Wheelin98TJ is offline
WJ: Cheapest shocks for 4" lift, What OEM Monroe shocks fit? iluvtruenos ZJ Grand Cherokee Forum 6 06-29-2009 01:05 AM
MX6 adjustable shocks ZJ 3"-4" lift rugermack ZJ Grand Cherokee Forum 8 04-07-2009 09:27 AM
wj 4" lift. What shocks?? 4x4jeepcrew ZJ Grand Cherokee Forum 5 03-01-2009 10:51 AM
4.5" lift shocks mk07138 ZJ Grand Cherokee Forum 2 12-01-2006 08:23 PM
