Will Larger Wheels Effect Performance ? - JeepForum.com
post #1 of 5 Old 06-19-2003, 09:38 PM Thread Starter
AllanLeigh
Hi, I am writing from Darwin Australia, and I am in the process of seriously modifying my stock 96 Grand Cherokee for the Kimberly region of north western Australia.
The max lift I can get from ARB here is 50mm, and I am thinking of changing my wheels for a slightly larger size by one inch in diameter, and maybe wider too.
I am concerned whether this may adversely effect the gearing and efficiency of the motor/gear train etc.
Can anyone help with their experiences please ?
Regards Allan Leigh
Hi To All From The land Of Oz
AllanLeigh is offline
post #2 of 5 Old 06-20-2003, 03:41 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Are you asking about increasing wheel size wider or taller. Most of the aftermarket wheels here are slightly larger than stock. Mine are slightly wider than stock.
If you go with a ricer type of wheel that is much larger than stock then, yes, your overall performance could be changed. Especially braking.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 5 Old 06-20-2003, 07:00 AM
Howler
The only thing that will be affected is your gas mileage. Increasing your height by 50 mm (2 inches) will allow you to fit tires that are 31" in height. However if you do a lot of off-roading then I would stick with a 30" tire to allow room to stuff your tire. After you put on the lift have a front end alignment done to keep everything in tune. A wider tire should be OK to. You might have slight rubbing on the control arms durring full turn but you can add washers to the steering stops or just not turn all the way. I run a 31" tire that is 10.5 " wide. I have rubbing only at full turn and I just left it. That way if I need to go all the way I can. Hope that answered your questions.
Howler
PS your gearing will be fine up until about a 33" tire. Then you'll notice it slow down a lot.
97ZJ 5.2L with 5" lift. 31" SuperSwampers TSL
To boldly go were no Grand has gone before.
Howler is offline
post #4 of 5 Old 06-20-2003, 10:55 AM
automan25
Going to a larger tire will also screw up your speedometer reading. It will tend to read lower than the speed you are actually going. So watch out for those cops.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #5 of 5 Old 06-20-2003, 11:08 PM
Ryan2son
Any deviation of wheel size will affect performance.
Richard
1999 Jeep Grand Cherokee Laredo
4x4, 4.7 V8, Quadratrac II, Loaded
A Hail the Mighty Philadelphia Eagles!
Ryan2son is offline
how does the " blend door " issue effect my AC ..??? bad effect ? sanboy WJ Grand Cherokee Forum 8 07-27-2010 12:22 PM
effect of pre cat on flow? ronsaun ZJ Grand Cherokee Forum 5 10-02-2009 09:47 AM
Larger tire sizes bring larger costs. Is this true? AEagle326 ZJ Grand Cherokee Forum 38 09-09-2008 07:46 AM
Does this effect Jeeps? AJ+SJ WK Grand Cherokee & XK Commander Forum 5 02-05-2008 07:43 AM
performance throttle body for 4.7 HO and performance cat converter mikkjroverland WJ Grand Cherokee Forum 0 02-07-2004 03:08 PM
