Will a double din fit? - JeepForum.com
post #1 of 21 Old 05-23-2013, 01:55 PM Thread Starter
xcaliber81
So basically im getting a freeway gps head unit free will it fit? I think its double din pretty sure it plays dvds to.
xcaliber81 is online now
post #2 of 21 Old 05-23-2013, 07:57 PM
Cherokee95kid
Should fit you might need one of these universal mounting brackets from best buy or Walmart or one of those places and make sure you have the right wiring harnes adapter
Cherokee95kid is offline
post #3 of 21 Old 05-23-2013, 08:25 PM
DickDickle
Double din units will not fit with out some decent modification, the dash bezel radio opening is barely big enough for a single din never mind the lack of space inside because of wiring and the vent plumbing
DickDickle is offline
post #4 of 21 Old 05-23-2013, 09:16 PM
Afdude88
Cut out the center vents and it'll fit. Will probably look like crap though.
1993 Grand Cherokee Limited 4.0L AW-4
1998 Grand Cherokee:
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #5 of 21 Old 05-24-2013, 05:47 AM
DickDickle
Will Def look like crap and I don't know about you but I like my center vents
post #6 of 21 Old 05-24-2013, 09:16 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You need to relocate the vents and the hvac head unit. Search, it's been done like twice over the years.
ratmonkey is offline
post #7 of 21 Old 05-24-2013, 04:37 PM Thread Starter
xcaliber81
Ill maybe just put it in my caliber then.
post #8 of 21 Old 09-17-2013, 10:32 AM
johns1mj
I am currently installing one in mine. I removed the inner radio bracket and relocated the extra wire harness behind the cluster. I cut the bezel with a hot knife and filled the sides to match the unit better. The radio is currently riding just in the dash. I am trying to get a two wheel drive cubby to remove the vic and install the bezel once. The screws above the stereo are very difficult to install and after the plastic removal the bezel isn't the strongest.
johns1mj is offline
post #9 of 21 Old 09-17-2013, 07:29 PM Thread Starter
xcaliber81
the one i was referring to was not double din but a slide out instead.
post #10 of 21 Old 10-04-2013, 04:40 PM
ewp418
How did the slide out work? I am thinking about getting one.
ewp418 is offline
post #11 of 21 Old 10-04-2013, 05:27 PM Thread Starter
xcaliber81
not to bad however the dash sticks out pretty far and its on a serious angle lol still useable i can take a pic if you like.
post #12 of 21 Old 10-04-2013, 05:30 PM
ewp418
A pic would be great. I am worried about the lip of the dash interfering with the angle.
ewp418 is offline
post #13 of 21 Old 10-04-2013, 05:37 PM Thread Starter
xcaliber81
give me some time its pouring rain and i worked all day out side i need to warm up for a bit lol.
post #14 of 21 Old 10-04-2013, 09:35 PM Thread Starter
xcaliber81
here you go hope this helps. I got this free and its a cheapo canadian tire deck. Has nav plays dvds and such. I had a hell of a time getting it to fit in such a small area so many pre outs and wires and such i had to remove the dash pad and tuck everything behind places lol.
post #15 of 21 Old 10-05-2013, 11:59 AM
ewp418
Thanks for the pics. I was hoping for a flush fit one but ghat would have to serious of an angle.
ewp418 is offline
