Will a cracked head or head gasket...... - JeepForum.com
post #1 of 3 Old 03-02-2009, 07:49 PM Thread Starter
jpl
Will a cracked head or a blown head gasket show signs during a coolant pressure test?
jpl is offline
post #2 of 3 Old 03-02-2009, 09:09 PM
ZeeJay1997
One way to check is take the radiator cap off, warm the engine up and look for air bubbles in the radiator. Or if you have an old cap, take the seal off, install it, warm it up and look for bubbles in the overflow tank.
Yes, you can check for internal leaks with a coolant pressure tester. Warm engine up until thermostat opens.
Attach a Pressure Tester to the filler neck. If pressure
builds up quickly, a leak exists as result of a
faulty cylinder head gasket or crack in the engine.
Repair as necessary.
WARNING: DO NOT ALLOW PRESSURE TO
EXCEED 124 KPA (18 PSI). TURN THE ENGINE OFF.
TO RELEASE THE PRESSURE, ROCK THE TESTER
FROM SIDE TO SIDE. WHEN REMOVING THE
TESTER, DO NOT TURN THE TESTER MORE THAN
1/2 TURN IF THE SYSTEM IS UNDER PRESSURE.
If there is no immediate pressure increase, pump
the Pressure Tester until the indicated pressure is
within the system range. Vibration of the gauge
pointer indicates compression or combustion leakage
into the cooling system.
Isolate the compression leak by shorting each
spark plug to the cylinder block. The gauge pointer
should stop or decrease vibration when spark plug
for leaking cylinder is shorted. This happens because
of the absence of combustion pressure.
ZeeJay1997 is offline
post #3 of 3 Old 03-04-2009, 09:35 AM
tazimafied
To answer your question. Yes. The pressure will leak down and you won't see coolant leaking anywhere.
Because I felt like it!
tazimafied is offline
4.7l oill fill spout gunk! Head Gasket? Cracked Head? kc8ztw ZJ Grand Cherokee Forum 10 10-29-2009 11:49 AM
Does this mean a cracked head? jpl ZJ Grand Cherokee Forum 15 06-04-2009 08:46 AM
Suspected Cracked 5.2 l head indianajeep ZJ Grand Cherokee Forum 6 01-06-2009 04:45 AM
4.0l Head Cracked Need Guidence rrrengine ZJ Grand Cherokee Forum 3 10-09-2008 10:02 AM
cracked head - buy new/ised/rebuilt Blake Rust ZJ Grand Cherokee Forum 4 08-11-2006 02:20 PM
