Will 31' tires fit? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Will 31' tires fit?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCount Down to KOH Sale!The Original 3/8" Ruffstuff Diff Cover!
Unread 08-26-2014, 09:20 AM   #1
NicCocco18
Will 31' tires fit?
Will 31' Goodyear Authority tires fit on my 1994 jeep grand cherokee?
NicCocco18 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 09:21 AM   #2
NicCocco18
Goodyear wrangler authority tires*
31 x 10.50 R15
Unread 08-26-2014, 09:22 AM   #3
mitchconley
With trimming and a small (1-2") lift
'99 XJ Limited
mitchconley is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 09:29 AM   #4
firsttimeZJ13
That's with a 2.5" lift. You will have to trim bumper. I did. Also, if you have stock wheels, you need to get wheel spacers, new wheels with 4" backspacing or never make sharp turns! I love those tires though, especially for the price.
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 09:37 AM   #5
AmishFury
31' tires will not fit....
31" tires however will fit with a little lift, trimming, and either spacers or rims with different backspacing
now these being a wal-mart exclusive you will likely not be able to get them mounted at walmart... the policy is to only mount the size listed on your tire placard, some stores will be flexible in this by mounting a size already on the vehicle
the workaround is to bring in the wheels off the vehicle the catch is doing it this way technically voids the road hazard warranty... or you can pay for the tires then take them elsewhere for mounting
AmishFury is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 10:04 AM   #6
firsttimeZJ13
They mounted mine for me.
Unread 08-26-2014, 10:43 AM   #7
NicCocco18
You have a 2.5' lift? I'm trying not to get a lift, or if anything just a very small cheap one. I'm On a budget they don't make those tires in size 30' unfortunately. So id need to turn the bumper and add what size spacers?
Unread 08-26-2014, 10:48 AM   #8
NicCocco18
Trim*
Unread 08-26-2014, 10:53 AM   #9
NicCocco18
What if I put new coil springs? Lifted ones, I saw a set of rustys 2.5 coil springs on craigslist for $100 wouldn't I need to get tranny drop? To angle it? Or Is it safe to just lift it up and replace the old with those? This is my first jeep and I'm 17. I'm trying to do things the right way but I don't a lot of money obviously. I just want it a little higher for trail riding and small mud holes
Unread 08-26-2014, 10:59 AM   #10
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Originally Posted by NicCocco18 View Post
I'm On a budget So id need to add what size spacers?
You can add washers to the steering stops. It will kill your turning radius, but cheap.
HighLonesome is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 01:00 PM   #11
firsttimeZJ13
Yes, I'm at 2.5. Still had to trim bumper, for spacers, 1.25 should be just fine. The only spacers I found, it was actually cheaper just to buy a set of pro comp steel wheels. Maybe you can find them cheaper! It does suck they didn't make 30's.
Unread 08-26-2014, 01:15 PM   #12
kg6mov
Hears the voices
kg6mov's Avatar
If you don't disco or flex you should be fine.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 01:40 PM   #13
NicCocco18
What did you need to do for your lift? Costs? Those rims act as spacers when you have bigger tires?
Unread 08-26-2014, 02:19 PM   #14
JohnnyZJ
JohnnyZJ's Avatar
you can buy what is called a 'budget boost' for under 200$ that includes new shocks.
or don't get bigger tires.
92 YJ ~ locked rollin' on 35s
05' WK Hemi limited ~ future plan?
14' GMC Terrain ~ wifes
13' GMC Sierra ~ 2.5" lift 33" toyos.
RIP 95 ZJ ~ 33s built/longarmed/locked/awesome Feb 2014 ZJOTM winner
JohnnyZJ is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 02:44 PM   #15
Bear304inc
I just put some JK wheels on my ZJ, they are 31s and they rub a little bit at full steer. And turning in reverse. You can get around town alright but I would not suggest doing any kind of real off roading.have no lift, yet but I do have my front bumper off. Im sure that does make a difference.
Edit: putting on the jk wheels required adapters tgat are 1.25" thick.
Bear304inc is offline   Reply With Quote Quick reply to this message
grand cherokee , tires
