Will 305-70-16's on stock rims rub rear shock? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Will 305-70-16's on stock rims rub rear shock?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!
Unread 05-07-2009, 10:48 AM   #1
(OllllO)
I got some new 305-70-16's that I want to run on my stock rims (silverblades) (2000 WJ). I would like to know if they will rub the rear shock before I have them installed. If they are gonna rub I might just sell the silverblades and get some soft 8's, or get some wheel spacers.
(OllllO) is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 10:58 AM   #2
liquid
I ran 285's on stock rims (Timberline), and every time I turned left, the exhaust pipe would swing and rub some of the outter lugs away..
I ended up putting on some 1.25" spacers
Karl
'00 WJ I6
liquid is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 01:26 PM   #3
comptiger5000
I would say you'd need the spacers. With spacers, it should work OK.
comptiger5000 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 06:14 PM   #4
(OllllO)
I'll probably go spacers since I like the wheels I have. Thanks for all the input.
Unread 09-15-2009, 01:55 PM   #5
(OllllO)
I got 1.25" spacers and it still rubs, but not as bad. Anyone moved there shock mounts to keep from rubbing?
Unread 09-15-2009, 02:02 PM   #6
ezflip
ezflip's Avatar
I have 245/70/16's and after my BB and Rough Country shocks, my tires rub on the shock now. Its not bad but it didn't do that before the BB.
~James
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's, 3" exhaust, Magnaflow hi-flow cat, Flowmaster 50 series
Build Thread
ezflip is offline   Reply With Quote Quick reply to this message
Unread 09-15-2009, 02:04 PM   #7
footinmouth47
did you get it aligned? properly?
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline   Reply With Quote Quick reply to this message
