Will A 242 Transfer Case From A 90 Cherokee Fit In My 99 Jeep Grand Cherokee.?? - JeepForum.com
post #1 of 9 Old 03-04-2009, 10:03 PM Thread Starter
squirrly
I CAME ACROSS A great deal on this and was wondering if I could use it in my 99 jeep grand cherokee.??
squirrly is offline
post #2 of 9 Old 03-05-2009, 09:39 AM
Scottso699
2006 WK
Theoretically it will fit with a lot of work but on the whole no. A 242 from a 90 cherokee most likely has a short 21 spline shaft - I am guessing you have a v-8 if you are looking for a swap - that would mean probably a long 23 spine shaft on your 247? But the other problem is the output shaft, output housing and shifter. The 99 and up transfer cases are cable shifted and everything up to 98 with a grand, 01 with a cherokee and all wrangers are shifted using a shift leverage system. The 90 cherokees use a gear on an insert in the tail housing of the transfer case for the speedometer. You'd have an enormous hole that would be uncovered and no good in that situation. The WJs also use an external slip yoke where as the 90 cherokees use an internal one. This would pose problems of driveshaft length for you. I would look for a transfer case out of a late model WJ Grand Cherokee v-8 (2003 or 2004 I think) that came with a 242. These are a heavier duty version than is found in the 6 cylinder WJ grands. Not only would this be a straight swap but would be the easiest way.
Scott
2006 WK Overland, OME HD Springs F&R, Bilstein 4600 Struts, 1.5" Rear Spacer, 265/70/r17 BFGs
Scottso699 is offline
post #3 of 9 Old 03-05-2009, 09:49 AM
ISUzj
2005 WK
I do have a 242j 02' if ur interested. PM me
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
ISUzj is offline
post #4 of 9 Old 03-05-2009, 12:54 PM
ZJcrawler45
yes but NO! stick with a 99-04. Anyways why would you want to put something in your heep that's 9 years older than it?
Captain Nate
ZJcrawler45 is offline
post #5 of 9 Old 03-05-2009, 05:12 PM Thread Starter
squirrly
cause its $50 bucks lol and I need one it was rebuilt and he has the paper work from the shop proving it thats why and thanx so much I wont get it now
squirrly is offline
post #6 of 9 Old 03-05-2009, 05:16 PM Thread Starter
squirrly
ISUZJ.. I DONT KNOW HOW TO PM.. LOL BUT I AM INTERESTED COULD YOU EMAIL ME dirtbikerider06@hotmail.com thank you
squirrly is offline
post #7 of 9 Old 03-05-2009, 05:21 PM
vansskaterfreek
aren't the speed sensors in different locations??
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #8 of 9 Old 03-05-2009, 05:40 PM
ISUzj
2005 WK
I don't know the numbers, I have to check the input and output spline count....will let you know..
~~~_______oooo_
ISUzj is offline
post #9 of 9 Old 03-05-2009, 05:55 PM
Scottso699
2006 WK
the WJs use the tone rings at the axle ends for the ABS to calculate the speed - if you look at a WJ Transfer case tail housing it has the area the early cases have bored for the speed sensor but it is just blank.
Scott
98 jeep grand cherokee 5.9 limited transfer case joshuatchandler ZJ Grand Cherokee Forum 22 08-27-2009 10:33 AM
1993 jeep grand cherokee transfer case blueknghts73 ZJ Grand Cherokee Forum 1 02-16-2009 04:20 PM
transfer case- 94 grand cherokee capone518 ZJ Grand Cherokee Forum 4 05-18-2008 11:00 PM
Transfer case vent tube 1999 Jeep Grand Cherokee WJ MNWJ ZJ Grand Cherokee Forum 2 11-01-2006 04:37 PM
1995 Jeep Grand Cherokee Transfer Case? blakely03 ZJ Grand Cherokee Forum 1 02-07-2006 09:05 PM
