Wife's ZJ has had full tune-up / overhaul, still throws code 43 - JeepForum.com
post #1 of 7 Old 08-19-2009, 04:15 PM Thread Starter
Crit
I've got an intermittent problem with my wife's ZJ. It's a 97 4.0 Auto 2WD. Plugs, wires, cap and rotor were changed about a year ago and look great. Two months ago, it got the following:
Brakes bled, turned, new pads, new shoes.
Removed and cleaned throttle body.
Injectors sent off to be cleaned and flowed - now within .5% of one another.
New fuel pump/screen/filter/accumulator telescoping bastard assembly.
New coil.
New cat and reworked the exhaust (straightening, rust removal).
It stalled on her today, for the first time in 2 months. It dropped from freeway speed to 30mph, then slowly recovered. Misfires, bucking, etc. seemed to be the symptom.
Historically, it seems to store code 43, and I've never gotten it to go away, even after all that work. Of course, it never misfired on me so I was hoping I had gotten away with the fix. Before she leaves today, she'll pull the code again but I fully expect it to be code 43. Code 43 reads:
Peak primary coil current not achieved with max dwell time
Cylinder misfire
Problem in power module to logic module interface
With the economy the way it is, I wanted to show the ZJ a little love and keep the wife in it a little longer. It's not bad on gas or insurance, and it's PAID OFF. Alternatively, can someone tell me where the power module and logic modules are? It almost reads like I could have a bad connection between them.
Please help me troubleshoot this thing before she starts shopping for a new car.
Crit is offline
post #2 of 7 Old 08-19-2009, 08:32 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
a 1997 should be giving you p-codes in the odometer when you use the key turn trick. those are obdi codes and do not apply to a 97.
a p0043 would be a shorted o2 sensor.
ratmonkey is offline
post #3 of 7 Old 08-19-2009, 10:08 PM Thread Starter
Crit
Crap, then it's not a 97. 95, perhaps. It definitely isn't OBD2.
Crit is offline
post #4 of 7 Old 08-20-2009, 08:59 AM Thread Starter
Crit
Correction - the ZJ is in fact a 97. The odometer spits out codes 12, 21, 43 and 55. When Autozone scanned the OBDII codes, it came back with upstream O2 (bank 1 sensor 1) and multiple misfires. I'm not worried about the O2, as bad as the car runs. The O2 sensor could have been telling the truth, and the mixture's just that screwed up.
I'm leaning toward blaming the crank sensor. I drove the Jeep last night and it finally died while I was behind the wheel. As much as it sputters and bucks, the tach jumps all over the place. I'm thinking that a crank position sensor that's losing counts would account for everything I've seen, as it'll run super-lean, thinking that the engine is suddenly running slower than it is.
Is the crank position sensor easy to change? I picked up the part and it looks simple enough, but I'm not sure how to access the current one.
By the way, am I the only one that thinks it's ridiculous that the dealer wants $110 for the same sensor that Autozone sells for $28? Good luck with that, Chrysler.
Crit is offline
post #5 of 7 Old 08-30-2009, 10:29 PM Thread Starter
Crit
I replaced the CKP, and the ZJ made it about a week before crapping out again. What's the next-likely offender? I'm thinking Cam Position in the distributor...
Crit is offline
post #6 of 7 Old 08-31-2009, 12:27 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Jeeps don't like non mopar sensors. Could easily still be the ckmp but could also be rhe cam sensor.
.go mooar though. Same with o2 sensors.
post #7 of 7 Old 08-31-2009, 01:08 AM
MN_NATV
A bad O2 sensor will make it misfire and generally run like crap, due to an incorrect air/fuel mixture. The O2 sensor will tell the ECM that the amount of oxygen in the exhaust is at one level when its at another level.
MN_NATV is offline
Code 37 - throws jeep into limp mode anticrombie ZJ Grand Cherokee Forum 7 09-28-2012 08:59 PM
Full tune-up HELP BHand89 ZJ Grand Cherokee Forum 11 11-05-2009 11:32 AM
5.2 zj(hesitates)throws lean fuel mixture eng. code??? ralph421 ZJ Grand Cherokee Forum 3 03-29-2009 06:04 PM
94 JGCL throws code #51 timbo114 ZJ Grand Cherokee Forum 2 05-24-2005 10:30 PM
Wife's WJ - Evaporative Leak Error Code ? binski ZJ Grand Cherokee Forum 5 01-13-2005 07:22 AM
