Quantcast Widest Tire on Zj? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Widest Tire on Zj?
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 10-23-2005, 09:51 PM   #1
xxdriverxx
Widest Tire on Zj?
Hey guys, new here, I just picked up a 96 Laredo (5.2) to replace my built up, all motor ford focus for the winter months..
It has the 15" wheel's and since I dont have the money for a lift or anything at the moment, Id like to atleast upgrade the tires to a more aggressive and slightly larger if possible size. The stock ones are pretty worn and the front left barely holds air so its definitly time for new ones. Im looking at the Dunlop Mud Rovers because there both cheap, and pretty aggressive. Just wondering if I could fit maybe a 245/75-15 or maybe wider/taller? current tires are 225/70-15's (not original though)
Thanks, Shawn
xxdriverxx is offline   Reply With Quote
Old 10-23-2005, 09:57 PM   #2
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
I had 30x9.5" BFG AT's on a stock UC ZJ and it was very nice. Can't put much more under a stock ZJ
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Old 10-23-2005, 10:00 PM   #3
trickle26
Here is some tire size info for you:
http://www.geocities.com/jeepfaq/index.html
97' ZJ Limited V8 - 5.2 liter
94' YJ 4.0 ho -SE -
past jeeps: 89' YJ
87' YJ Laredo
88' YJ Sahara
90' XJ Limited
trickle26 is offline   Reply With Quote
Old 10-23-2005, 10:50 PM   #4
xxdriverxx
Well now that ive been looking around for a while, If I went with these-
http://www.kevinsoffroad.com/acos.html
Set to max height, I could fit a 31x10.50" tire with no rub,correct? If not how big could I go, and how will this affect my gearing, since im running the stock gears..
Also, should I add wheel wideners if I go with a 10.5" wide tire?
Thanks again, Shawn
Old 10-24-2005, 05:27 AM   #5
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You can run a 31 with a lot cheaper coil spring spacer lift called a BB from Kevins rather than the acos.
You'll want to upgrade your wheels to aftermarket ones with 3.75 to 4 inches of backspacing to prevent tire rub on the inside of the wheelwell.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 10-24-2005, 04:07 PM   #6
xxdriverxx
Ok so with the BB, and some 31x10.50's ill be good, but how will my gearing suffer, or will it not be too noticible with the 5.2L.. Also, can I just buy some wheel wideners as I dont want to upgrade wheels, stock look good, and I dont have the money for new wheels. (saving money to turbo my other car)
-Shawn
Old 10-24-2005, 04:21 PM   #7
RAAB3485
Viewer Discretion Advised
RAAB3485's Avatar
Buy a set of Black Steel wheels for your Jeep. They are very cheap, (we bought a set of 5 for my girlfriends TJ for 150 shipped) they look good and you can get proper backspacing that way. There are a lot of guys on here running them, I'm sure someone can help me out with a pic of a 2 inch BB on a ZJ with Black Steelies.
Gearing you should be fine, your speedo won't be right anymore though.
Eric
2006 Wrangler Unlimited
Colorado Jeep Club Member #1
RAAB3485 is offline   Reply With Quote
Old 10-24-2005, 10:58 PM   #8
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You can usually find a wheel and tire combo from www.ntwonline.com, www.4wheelparts.com, www.desertrat.com for cheaper than you can find 4 new tires out in town.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
Glock Forum
