Quantcast Widest Rim/Tire Fit WJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Widest Rim/Tire Fit WJ?
Old 01-29-2007, 03:50 PM   #1
RrCoX22
Will a 10" wide rim clear without trimming. Im sure backspacing can help a bit. I want to know if a 15X10 Pro Comp Rock Crawler w/3.75" backspacing will fit while being wrapped in a Pro Comp 31x12.5-15 Will this clear without any trimming or slight trimming. I will have KOR 2.5" BB before this temporary setup goes on.
[FONT="Impact"][SIZE="3"]1997 5.2L [COLOR="Red"]ZJ[/COLOR] [COLOR="DimGray"]Limited[/COLOR][/SIZE][/FONT]
[URL="http://www.norcal4x4forum.com"]Norcal 4x4 Forum[/URL] | [URL="http://www.fquick.com/RrCoX22"]My Garage[/URL]
RrCoX22 is offline   Reply With Quote
Old 01-29-2007, 04:22 PM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
So 15x10" 3.75" BS rim with 31x12.5" tires? It'll probably require minor trimming on the bottom part of the front bumper when in reverse and wheels turned, but nothing major.
Thats a really wide rim and personally makes it look like a ricer(but if thats what your after, go for it) - I would go with 8" personally.
ArloGuthroJeep is offline   Reply With Quote
Old 01-29-2007, 04:30 PM   #3
RrCoX22
the only reason why im going with such a wide rim is because im going to eventually be going with a 36" TSL (or larger) which requires a wide rim, so i don't want to but two seperate sets of rims
Old 01-29-2007, 04:48 PM   #4
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You can run 36s on a 15 x 8 all day.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 01-29-2007, 05:37 PM   #5
Woody
Retired back to Bowties
Woody's Avatar
1985
My best friend is running 39.5" x 15" boggers on 16x8 rims.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
Old 01-29-2007, 06:42 PM   #6
RrCoX22
well i guess i actually like the wide tire, sticking out look instead of the skinny meats
think it looks badass when the tires are wider then the chassis instead of being swallowed by it.
Old 01-29-2007, 06:44 PM   #7
ArloGuthroJeep
Mr. Hyde!
Yeah, but accomplish that by less backspacing or wider axles, not a wider rim (which won't push the tire out that much). Plus when you air down with a wide-rimmed wheel you'll pop a bead easier.
Glock Forum
