Why would I want the 9'er? - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Why would I want the 9'er?
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 03-22-2013, 01:46 PM   #46
PolkaPower
Originally Posted by angry_trucker View Post
5.9 sounds like lots of power, but wondering if the rest of the Jeep is up to it, as far as the stress to the transmission/rear end is concerned?
You can just read the specs but I'll just tell you so you don't have to put forth the effort. It's got a D44a in the rear(same used in Vipers and Corvettes), thicker rear drive shaft, and the same transmission used in full size Dodge trucks. 46RE. The 5.2 has a 44RE. The 249 has a bigger input or output shaft I think. The one bad thing about it is no auxiliary transmission cooler but you can add one.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 03-22-2013, 01:53 PM   #47
kg6mov
kg6mov's Avatar
It should have the aux cooler from the tow package though right? Maybe tow package was still optional? I know my 96 w/ tow package has the cooler, and I assume my niner does.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
kg6mov is online now   Reply With Quote Quick reply to this message
Unread 03-22-2013, 01:58 PM   #48
PolkaPower
No. Aux coolers discontinued on all 98 models after radiator redesign which was a bad idea.
Unread 03-22-2013, 02:01 PM   #49
kg6mov
kg6mov's Avatar
Whoa damn, learn something new everyday. Guess I know what I'm adding to the niner next.
Unread 03-22-2013, 02:02 PM   #50
PolkaPower
I put a plate and fin on there rated for 30,000 GVW.
Unread 03-22-2013, 09:40 PM   #51
MN59ZJ
Not to the point you need to own a tire tread depth gauge & need to know the nearest shop that shaves tires when they get out of whack. Throw the spare into the rotation & you have a real headache.
MN59ZJ is offline   Reply With Quote Quick reply to this message
Unread 03-22-2013, 09:44 PM   #52
MN59ZJ
Nah, they're both the same as any ZJ.
Unread 03-22-2013, 11:47 PM   #53
98Five9er
I have a Niner and haven't driven a 5.2 to compare, but I can tell you the thing is POWERFUL, riding around with my exhaust valve open, its louder than any truck on the road, and definitely has the speed to back it up. I wouldn't have gone out of my way to find one, but an opportunity fell on my lap when my friend sold his to me for 1,100 bucks. Couldn't go wrong for that price.
98Five9er is offline   Reply With Quote Quick reply to this message
Unread 03-22-2013, 11:47 PM   #54
PolkaPower
the "special" 249 for the 5.9, which isn't marked as special in ANY way, supposedly has a beefier main shaft, wider chain, and more planetary gear pinions.
Ratmonkey quote. http://www.jeepforum.com/forum/f13/9...-shaft-960607/
I can't verify this but I have read that it was stronger in some way.
Unread 03-22-2013, 11:56 PM   #55
PolkaPower
The VC in mine lasted 130k miles. I'm happy with it lasting until 260 k miles after replacement.
Here is a quote from a fellow from expedition portal about the 249
Unread 03-23-2013, 12:16 AM   #56
dnuccio
if anything ever happens to my ZJ, the next one WILL be a niner!
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 01:11 AM   #57
ratmonkey
R.I.P.
ratmonkey's Avatar
that's what i've heard from a few of the people that regularly rebuild the jeep cases. 6 pinion planetary, wider chain, and thicker main shaft. outputs and inputs are the same though.
the rear driveshaft uses 1330 or 1350 joints, i forget which, but i know they're bigger than the 1310 joints a normal zj uses.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 01:34 AM   #58
jenniferny
I ordered a 98 Limited with a 5.2 because the salesman never told me about the 5.9 or offered me a test drive of one. When it finally came I liked it loads more than my 4.0 G C. The day my lease was up, I wrote a check and paid off the 5.2 and went looking for a 5.9. Found one with lower miles than my 5.2 and worked a deal. I have never once regretted my move to the 5.9. I will probably drive it till all the oil in the ground is gone or I am in the grave.
[COLOR="Magenta"][SIZE="5"][FONT="Times New Roman"][B][I]Jennifer[/I][/B][/FONT][/SIZE][/COLOR]
jenniferny is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 04:09 AM   #59
Exdecuk
Its got bigger main bearings too
A man will pay $2 for a $1 item he needs.
A woman will pay $1 for a $2 item that she doesn't need but it's on sale.
Exdecuk is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 06:29 AM   #60
newfieZJ
The mainshaft is the only difference in the 5.9's 249 . Parts list has the same listing for all other parts including the input shaft and chain .
newfieZJ is offline   Reply With Quote Quick reply to this message
