Why would I want the 9'er? - Page 2 - JeepForum.com
post #16 of 150 Old 03-21-2013, 05:19 PM
kg6mov
Hears the voices
kg6mov's Avatar
And the niner doesn't suck more gas than the 5.2, the basic theory is that the engine has to work less because it's more powerful so fuel evens out. Thats why the 4.slow is so bad on gas, it's underpowered for the vehicle.
9er does take premium though.
kg6mov is online now
post #17 of 150 Old 03-21-2013, 05:20 PM Thread Starter
chich
Originally Posted by kg6mov View Post
Efan is standard on niners, all others had clutch fans. At least in the US.
Then I stand corrected kgm6ov.Didn't know that.Thanks for the info
chich is offline
post #18 of 150 Old 03-21-2013, 05:27 PM
PolkaPower
You can get an SCT tuner that will reprogram the PCM to run regular fuel and not lose power. It comes with economy, towing, and performance. The difference between regular and premium around here is 24 cents as far as the "spending more on fuel" argument. If you toss in 15 gallons you would only be paying 3-4 bucks more for the 5.9 and if you can't afford 4 extra bucks for gas then you shouldn't have a Jeep to begin with.
PolkaPower is online now
post #19 of 150 Old 03-21-2013, 05:30 PM
LunaMoona
Personally, I'd love to take a 360 and swap it into my '93 instead of buying a 5.9l. But that's just me.
LunaMoona is offline
post #20 of 150 Old 03-21-2013, 05:32 PM Thread Starter
chich
well,here's one that's' available that looks appealing:
http://newyork.craigslist.org/brk/cto/3686035754.html
chich is offline
post #21 of 150 Old 03-21-2013, 05:37 PM
Dyn0mitemat
That isn't a bad deal at all if everything check out
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #22 of 150 Old 03-21-2013, 05:41 PM Thread Starter
chich
Unfortunately, I'd have to sell my 5.2 before I could bite the bullet and by the time I do that it'll probably be gone. So maybe one of you guys should jump on it
chich is offline
post #23 of 150 Old 03-21-2013, 05:43 PM
PolkaPower
Any V8 ZJ you buy you will probably have to sink 1000 dollars into it just fixing the worn out parts. Viscous coupler, bushings, plenum gasket, ect. I have almost got mine in tip top shape and I got it in 8/11, just a few more things to fix.
post #24 of 150 Old 03-21-2013, 05:46 PM Thread Starter
chich
You're spot on there Polka,when I got my 5.2 a couple of years ago that's about what I put into it to get it "right".
chich is offline
post #25 of 150 Old 03-21-2013, 05:48 PM
MN59ZJ
It's better looking, better performing (was the fastest SUV made for many years) has a stronger transmission, yeah it's 15 years old, but most other ZJs are older & none are newer. When you do have to dump money into it, it doesn't hurt as bad, because you're keeping a limited production vehicle going.
But yeah, If you have to ask...
MN59ZJ is offline
post #26 of 150 Old 03-21-2013, 05:51 PM Thread Starter
chich
What is all this BS about having to ask???You're about the 5th guy that said that
chich is offline
post #27 of 150 Old 03-21-2013, 05:53 PM
PolkaPower
You aren't ready yet dude.........
post #28 of 150 Old 03-21-2013, 05:57 PM Thread Starter
chich
When you are ready grasshopper...you will know
chich is offline
post #29 of 150 Old 03-21-2013, 06:14 PM
martymars
Stop with the "if you have to ask" sheet. Sound like arseholes.
martymars is offline
post #30 of 150 Old 03-21-2013, 06:16 PM
misfit77
I would say power is not the only thing you gain...you also get a crappy transfer case that most people downgrade.
misfit77 is offline
