Why is speed proportional steering a bad thing - JeepForum.com
post #1 of 10 Old 01-24-2014, 05:02 PM Thread Starter
RoldGold
Over the past couple weeks I've noticed quite a few forum posts that say to avoid the 96 PS pumps that have the proportional steering. I've got it, and this being my first car, I don't know what's bad about it. Why should I avoid it/should've avoided it?
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
post #2 of 10 Old 01-24-2014, 06:01 PM
shaban
Nothing's wrong with it. Speed proportional steering uses a different spool valve in the steering box and a different pump, so they are not not interchangeable with regular pumps/boxes, only as a set.
So if you've got a speed proportional steering, you can only swap in SP pump and SP steering box.
If you've got a regular steering, you can only swap in regular pump and regular box.
I've put a non-SP box from an XJ into my ZJ when mine blew (it was a SP box) and it worked fine, however there's something in the FSM that says "steering response may be affected if doing so".
shaban is offline
post #3 of 10 Old 01-24-2014, 07:20 PM
KJK
The "bad" part is the components are more expensive when it comes time to replace them. Other than that, it's fine.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #4 of 10 Old 01-24-2014, 07:36 PM
Purcell69
When combined with a five speed MT, it can be annoying. There is nothing worse than turning to pull in to a parking space in a crowded lot, pushing in the clutch to coast in and having the engine drop to idle and at the same time, the PS feels like a manual steering box all of the sudden. Usually I "blip" the throttle while holding the clutch. After 21 years with this Jeep, I am used to it, but it still surprises me from time to time.
-Joe
Purcell69 is offline
post #5 of 10 Old 01-25-2014, 12:24 AM
KJK
Originally Posted by Purcell69
When combined with a five speed MT, it can be annoying. There is nothing worse than turning to pull in to a parking space in a crowded lot, pushing in the clutch to coast in and having the engine drop to idle and at the same time, the PS feels like a manual steering box all of the sudden. Usually I "blip" the throttle while holding the clutch. After 21 years with this Jeep, I am used to it, but it still surprises me from time to time. -Joe
It should have the most assist at idle and less as the rpm increases.
KJK is offline
post #6 of 10 Old 01-25-2014, 02:32 AM
5-90
5-90's Avatar
1988 XJ Cherokee
I don't like it because I expect consistent behaviour from my vehicle's systems, I don't like it when they change for whatever reason.
I don't like ABS for the same reason - and it gets all screwy when I "feather" the brakes to slow down, as I was trained to do.
I definitely don't like any system that I can function without, don't want to pay for, but am forced to have anyhow (ABS, for starters.) I don't like "safety devices" that allow a driver to abdicate responsibility - since I was trained to take responsibility for anything that happens as a result of my maintenance or operation of a vehicle. I don't like the trend toward "smart" cars that allow stupid drivers.
"Feature creep" in creature features is bad enough - but when it's mandated as a "safety push," I draw the line. Your #1 safety device is that mushy 1800cc or so between your ears - if you can't use that properly, then nothing else will be of any help to you (if you can use it properly, you don't need anything else.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #7 of 10 Old 01-25-2014, 10:58 AM
Technohead
Exactly, the more complicated it is the more that can go wrong.
-Eric
Technohead is offline
post #8 of 10 Old 01-25-2014, 11:15 AM
dusterdude
Not sure about stupid drivers,but lazy sure fits the bill
dusterdude is offline
post #9 of 10 Old 01-25-2014, 03:53 PM
Purcell69
That's funny. At idle the PS has a 50/50 chance at being normal or sluggish and has always been that way since day 1 (new). Above idle, the PS feels normal. I just figured it was proportional steering, as was told by the dealer about 20 years ago. It's been annoying, but if it ain't broke....
Now you've given me a reason to try and fix it. Damn.
-Joe
post #10 of 10 Old 01-25-2014, 05:13 PM
shaban
As far as I know, PS just reduces the amount of assist at 40+ speeds, full assist at idle or slow speeds.
Mine's working fine at idle by the way, and I've got a speed proportional.
shaban is offline
