Why So Much Vibration? - JeepForum.com
post #1 of 7 Old 03-18-2003, 10:10 PM Thread Starter
GrandRubicon155
I have a Rubicon Express BB with goodyear 30 inch tires and when i hit 55 mph my steering wheel vibrates very hard. I replaced my steering stabilizer with the skyjacker heavy duty and it helped a little but the vibrations are still comming. Could this be warped roters?
GrandRubicon155 is offline
post #2 of 7 Old 03-19-2003, 02:23 AM
Ryan2son
Are your lug nuts tight? I would also suspect a tread separation (between the tread and belts) or a bushing issue. I don't think it's the rotors because you're going 55 mph and not depressing the brakes...
Richard
1999 Jeep Grand Cherokee Laredo
4x4, 4.7 V8, Quadratrac II, Loaded
A Hail the Mighty Philadelphia Eagles!
Ryan2son is offline
post #3 of 7 Old 03-19-2003, 06:56 AM
Stocker
Tire balance? Try rotating front to rear and see if there is any difference, better or worse. If it changes at all, I would suspect balance problems.
I agree with Ryan2son - doesn't sound like rotors.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #4 of 7 Old 03-19-2003, 08:12 AM
Howler
How did you put your BB in? If you loosend any of the bolts to the control arms, trac bar or any sterring component this will aslo do it. The main culprit out of those 3 is the trac bar. It seams tight when you first put it on but it is not. Retighten all you bolts again.
Howler
97ZJ 5.2L with 5" lift. 31" SuperSwampers TSL
To boldly go were no Grand has gone before.
Howler is offline
post #5 of 7 Old 03-19-2003, 01:04 PM
demtjcj
you could run an aftermarket steering stab
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #6 of 7 Old 03-19-2003, 04:48 PM
demtjcj
my bad didnt see you already did
demtjcj is offline
post #7 of 7 Old 03-21-2003, 07:05 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Did you bother getting it aligned after the install?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
vibration rmtomasin ZJ Grand Cherokee Forum 11 03-26-2009 09:40 PM
vibration driabyor ZJ Grand Cherokee Forum 5 06-23-2005 09:24 PM
I6 vibration... CBlakeNS ZJ Grand Cherokee Forum 13 04-20-2005 09:43 PM
Vibration at 65+ MPH ats1968 ZJ Grand Cherokee Forum 1 02-12-2005 11:15 PM
vibration 01grander ZJ Grand Cherokee Forum 3 01-18-2005 07:34 AM
