Why shouldn't you use a tcase drop on a zj? - JeepForum.com
post #1 of 7 Old 06-30-2013, 08:36 PM Thread Starter
jm8881
I keep reading on here that you shouldn't install a tcase drop on a zj but almost all lifts come with one.
What is it that the jeepforum users know that iro, kevins, rc, bds, etc. don't know?
jm8881 is offline
post #2 of 7 Old 06-30-2013, 08:55 PM
dnuccio
its not needed.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 7 Old 06-30-2013, 08:57 PM Thread Starter
jm8881
Usually not needed or never needed? I just can't wrap my head around why a company would go through the r&d process for a product that isn't needed.
jm8881 is offline
post #4 of 7 Old 06-30-2013, 08:57 PM
riot1987
Ive seen many many lifted rigs with out them that operated perfectly. Dont see the point in adding one if not needed
Build thread^^
riot1987 is offline
post #5 of 7 Old 06-30-2013, 09:22 PM
um7267
maybe if it has a 7+ lift
but if you drop the back end of the transfer case the front would still be high and what would the point be of the lift if you drop the case down 3 inches? on a zj your best bet is a high pinion axle front and back, and if you have money than do it right and get better axles
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #6 of 7 Old 06-30-2013, 09:35 PM
WhiteOut
WhiteOut's Avatar
The rear driveshaft in the ZJ is long enough that even at 7" of lift you don't need to be messing around with it. The operating angles are fine for the joints on the drive shaft. A transfer case drop will actually hurt the front angle, not to mention lose you clearance that you just paid hundreds of dollars for. The front shaft should be addressed (lengthening/swapping joint styles) if needed. HP axles are not "needed/best bet" and you can safely run larger tires on non-HP axles.
On a TJ or the SWB Jeeps, the rear driveshaft is much shorter and lifting puts it at a steeper angle.
WhiteOut is offline
post #7 of 7 Old 07-01-2013, 09:14 AM
PolkaPower
Yea but the local 4x4 shop who works on Chevys and Fords said I would need one along with a drop pitman and SYE.
PolkaPower is offline
