Why is my passenger floors' carpet wet??? PICTURE INSIDE - JeepForum.com
post #1 of 10 Old 09-24-2009, 01:00 AM Thread Starter
ef1992
What in the heck could this be from? I was washing her the other day and the carpet felt a little damp so I looked under the mat and it was like soaking. So I pried up the carpet and it was like ****in wet with what I assume is water!
It still is wet, and when I blot and dry it, it just comes back.
2001 Grand Cherokee Limited-4.7 V8-Quadra Trac II-Flowmaster Super 44 with 3" exhaust
Last edited by FPKites; 09-27-2009 at 09:44 AM. Reason: Let's not bypass the censor, okay?
ef1992 is offline
post #2 of 10 Old 09-24-2009, 01:04 AM
sandman
ac drain could be clogged, or a door seal or sunroof seal could be bad.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 10 Old 09-24-2009, 01:24 AM Thread Starter
ef1992
Ill check the door seal
I have no sunroof :/
is it bad to have a clogged ac
ef1992 is offline
post #4 of 10 Old 09-24-2009, 02:12 AM
CaribouLouWJ
2007 WK
do you smell coolant?
2007 WK Overland
5.7 Hemi, 18% tint, baby seats
2000 F350 PSD CC LB
2001.5 B5S4 500awhp gutted track car
2002 WJ Limited
4.7 HO, 6.5" LA, 37's, JK 44's SOLD
CaribouLouWJ is offline
post #5 of 10 Old 09-24-2009, 02:15 AM Thread Starter
ef1992
I dont know what coolant smells like, but the liquid smells like water! and I dont smell anything in the cabin
ef1992 is offline
post #6 of 10 Old 09-24-2009, 02:43 AM
CaribouLouWJ
2007 WK
coolant smells sweet. Do you get foggy windows in the AM when you first turn on the heat?
2007 WK Overland
2000 F350 PSD CC LB
2002 WJ Limited
post #7 of 10 Old 09-24-2009, 06:51 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Clogged ac drain.
You should really take the time to read through the faq at some point.
ratmonkey is offline
post #8 of 10 Old 09-24-2009, 06:59 AM
Turbonut
Take some blue paper towels and lay them all around the floor next to the firewall, kick panel, and door area to see where the water in entering. Use blue as they are much easier to view the wet area. After you narrow down the area, start looking.
I even had an older GC that the caulk on the body seam in front of the windshield became hard and brittle, so water leaked in and entered the cabin under the kick panel.
Turbonut is offline
post #9 of 10 Old 09-24-2009, 11:32 AM
WXman
unfortunately that is common on WJs. My mother's 04 does the same thing. we traced it to a fautly seam not welded properly inside the passenger fender (near the radio antenna). it's a pita to get to the area where the water comes from. but everytime it rains, you can expect a floor full of water.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #10 of 10 Old 09-26-2009, 05:41 PM
urq2
urq2 is offline
Passenger Airbag Lights On Without A Passenger Macguba798 WK Grand Cherokee & XK Commander Forum 7 01-21-2009 08:48 AM
wet floors in my 98 Grand Cherokee LTD boeckm ZJ Grand Cherokee Forum 6 07-17-2008 07:01 PM
Passenger carpet wet... A/C leak? Country Jeep ZJ Grand Cherokee Forum 3 07-18-2007 12:27 AM
water leaking inside passenger side hellrazor ZJ Grand Cherokee Forum 1 06-23-2007 11:47 PM
ac evaporator drain rear floors wet again...95 Grand Cherokee foxtrot ZJ Grand Cherokee Forum 3 08-02-2005 07:45 PM
