Why doesn't anbody run 10" rims?? - Page 3 - JeepForum.com
post #31 of 36 Old 04-13-2011, 07:23 PM
tato1111
I used to have 10's. now i have 8's, there is no diffrance in preformance imho.
White zj 6in. 33x12.5 1995
<--Mods in profile
tato1111 is offline
post #32 of 36 Old 04-13-2011, 07:30 PM Thread Starter
speedbucket
jeeps are made to be dirty. haha, that reminds me of a guy i used to work with. he bought a "show" truck early 90s f350 on 38s. this thing was SPOTLESS. the guy signed the title over and he literally drove it over the curb/ditch and in to a field next to the foodlion parking lot and wrapped it up. the seller looked like he was gonna cry. his old truck had never left the pavement
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #33 of 36 Old 04-13-2011, 07:35 PM
squazz
so i understand the weight difference between a 10" steel and a 10" aluminum is great but im still wounder which holds the bead better
squazz is offline
post #34 of 36 Old 04-13-2011, 07:40 PM
MStaffin
I think steel.
00 WJ Zone4in Clayton longarms and linked rearD30/D35 4.88s 33s locked
MStaffin is offline
post #35 of 36 Old 04-13-2011, 07:44 PM
94jeeprc
1994 ZJ
Originally Posted by speedbucket View Post
i looked up the gamblers, definetly aged
im lucky enough to have these beauts ! not sure what they are called
i have them on my jeep and hate them can't wait to change them for something a little better looking .
I thought they was called "honeycomb" aluminum wheel .
that is what i got from the specs on my jeep when i looked it up stock.
i would like these with some nice tires .
http://www.4wd.com/productdetails.aspx?partId=61498#
94 jeep gc limited 5.2l v8,all stock 46rh trans,honeycome rims michelin tires 30,s
plan on lifting 3" ,upgraded form 249 quadtrac to 242 selec-trac tc .
all memphis coaxials in doors,clarion head unit ,2 15's in the back .running off
2 6500 watt amps ,with 2 12v batteries. CAN you say bye bye rear view mirror.
94jeeprc is offline
post #36 of 36 Old 04-14-2011, 06:35 AM
KyBoy1991
http://www.ultrawheel.com/wheel_deta...brand=1&id=111
Buy those, they also come in Black and save you some money over buying from 4wd......just sayin. Go to a BigO or some local place that carries them and you'll save $100 easy over the cost of 4.
As far as someone saying the steel holds the bead better over aluminum....I'm pretty sure it all depends on how the wheel is constructed, how the tires bead is constructed, and how well someone knew what they were doing when mounting them.
I personally think if aluminum was so bad at holding a bead, than the new vehicles wouldn't be allowed to run the alloy/aluminum wheels. You have to take into consideration how few ppl in the world who drive will actually pay attention to their psi in their tires. Many Many times they run them so low without knowing how to put air in them, drive the car like they stole it, and the bead never pops or slips.
Me personally, i've had nothing but aluminum wheels....other than when i had my 78 CJ7 with white wagon wheels....and I've NEVER threw a bead or slipped one. I've been as low as 8psi before as well. I've also never run anything larger than a 33x12.5....so not sure going below 8psi on a tire that small is possible or necessary.
KyBoy1991 is offline
OEM 18" rims,backspacing and "The Bolt" Robert J. yates WK Grand Cherokee & XK Commander Forum 8 10-24-2009 09:52 AM
Trade - my 17" cast alum. machine face rims for your Chrome Clad alum. rims coyote runner WK Grand Cherokee & XK Commander Forum 2 08-13-2007 05:03 AM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 11:23 AM
3" lift, 285-75-16 stock limited rims, and 1"wheel spacer. Will it work? bjl95mustang ZJ Grand Cherokee Forum 1 01-26-2006 11:17 AM
Has anbody pulled ignitition switch? Pitch Black ZJ Grand Cherokee Forum 6 12-12-2005 07:31 PM
