Why do my new Bilsteins look so wack? - JeepForum.com
post #1 of 15 Old 10-27-2016, 02:14 PM Thread Starter
KiloWatts
I took everyone's advice and sprung for the Bilstein's. Great ride! I can see why people like them.
However, both the front boots are all whacked. Back boots look fine. Not that it matters, but still...
1996 4.0 L6 2WD. Exciting.
KiloWatts is offline
post #2 of 15 Old 10-27-2016, 02:27 PM Thread Starter
KiloWatts
Well that was easy. Just slipped the ziptie down.
Too bad it won't compress evenly though.
post #3 of 15 Old 10-27-2016, 03:21 PM
GOLDWING
Those boots do more harm than good IMO. Dirt and crappy water will get in and then just sit there ruining your new shocks.
GW
2 '98 4.0 ZJs
Hers is stock, mine, OME shocks, BB, Aussie, 2x6 sliders, 31s, etc.
GOLDWING is offline
post #4 of 15 Old 10-27-2016, 04:47 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
On the top pic, you need to slide the boot down farther on the shock tube. Or just get rid of them as suggested.
HighLonesome is offline
post #5 of 15 Old 10-27-2016, 09:00 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Never had issues with shock boots. Why do you guys always have issues with them?
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 15 Old 10-27-2016, 09:25 PM
monte350
not to derail the OP's thread any farther, but i also have questions about the shock boot hate. for those without boots, do the shafts get sandblasted being exposed?
1995 Cherokee(XJ)-Rolled it
1998 Grand Cherokee(ZJ)-Sold it
1997 Grand Cherokee(ZJ)-DD
monte350 is online now
post #7 of 15 Old 10-27-2016, 09:34 PM
GOLDWING
Must be something to do with the environment the shocks (and boots) run in. I've never had a shock issue related to dirt, water, mud or whatever hurting my shocks. I have never had a boot on a shock, However, I have had a sock in a boot.
GW
2 '98 4.0 ZJs
GOLDWING is offline
post #8 of 15 Old 10-27-2016, 11:49 PM
CatSplat
1994 ZJ
Shock shafts are hard-chromed and extremely resilient to wear. The internal seals generally wear out long before the shock shaft is compromised, barring extreme circumstances.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #9 of 15 Old 10-28-2016, 09:44 AM
PolkaPower
If you are in water, mud, or wet salty snow a lot then the boots hold in a lot of crap.
PolkaPower is offline
post #10 of 15 Old 10-28-2016, 10:22 AM
HighLonesome
On motorcycle fork boots the seal is complete and not much crap enters. On shocks there are holes at the bottom of the boot that let in crap. Why? I don't know.
post #11 of 15 Old 10-28-2016, 10:31 AM
PolkaPower
They are supposed to let water out I guess.
post #12 of 15 Old 10-28-2016, 01:41 PM
PCsZJ
Let the air out when it compresses. Or back in when it extends. Like an accordion. Otherwise going to be sucked flat or blown out.
PCsZJ is offline
post #13 of 15 Old 10-28-2016, 02:42 PM
PolkaPower
That makes more sense
post #14 of 15 Old 10-28-2016, 03:04 PM
Timo_90xj
Timo_90xj's Avatar
Moisture, road salt, mud, all other crap starts accumulating inside them causing corrosion and even wiper seal issues. Especially in winter when the shock boots get brittle and crack, snow and ice start to build up inside as well.
I've never had any issues on dirt bikes/ MX bikes, DH bikes, Jeeps nor any other apparatus that has shocks without shock boots. Shock shafts stay nice, clean & shiny. I prefer not having them, because:
* shock boots look fugly
* they serve absolutely no purpose whatsoever
* in my experience they do more harm than good
***Under construction***
Timo_90xj is offline
post #15 of 15 Old 10-28-2016, 04:07 PM
denverd1
In a salt free area. No boots on mine. Look new after 2 years
Sent from my SAMSUNG-SM-G930A using Tapatalk
98 XJ: 4.5" lift, winch, F/R locked on 33's
2009 WK: Ltd Hemi QDII 33's, SRT8 intake, Superchips
denverd1 is offline
