why? - JeepForum.com
post #1 of 7 Old 12-25-2001, 08:02 PM Thread Starter
Big Dumb White Guy
Big Dumb White Guy's Avatar
why?
what is going bad on my 4.0l i6 engine? sometimes the gage shows 14 volts and sometimes (usually at an idle) just barely 10 volts?
altenator??? what do you think??? need help. blew out 1 head light already......
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #2 of 7 Old 12-25-2001, 08:15 PM
Kess
to test ur alternator, start the vehicle then go under the hood and disconnect the positive battery cable, if it dies down at all, not necessarlily stalling, but if it dies down the alternator is bad, if not the reason the meter is reading low will be an internal battery problem, hope this helps
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
post #3 of 7 Old 12-26-2001, 12:24 AM
horatio102
Take it into a Schuck's (Kragen/whatever is in your area) and have them do a charging system test.
horatio102 is offline
post #4 of 7 Old 12-26-2001, 08:09 AM Thread Starter
Big Dumb White Guy
ok got codes out of ZJ
1.) #12 problem with battery connection. direct battery input to PCM(?) disconnected within the last 50 ignition cycles. i disconnected the battery to add a stereo.
2.) #24 throttle position sensor voltage high/low. test throttle position sensor. where the heck is that?
3.) #34 open or shorted condition detected in the cruise control or vent solenoid circuits. what the heck does that mean?
any one of these can make my voltage jump around like that???
repost Nazi's suck!
post #5 of 7 Old 12-26-2001, 09:52 AM Thread Starter
Big Dumb White Guy
i called a mechanic friend of mine. he said that it sounded to him like the altenator. because i am getting those codes about the voltage problems. i bought 1 off (165 amp) of e-bay for $135. my buddy wanted $225-275 for an altenator and 1 hour labor. it ranged from used alt to brand new.... hopefully i get the new one soon!!!
let you know results later....
repost Nazi's suck!
post #6 of 7 Old 12-26-2001, 12:42 PM
horatio102
DANG! I bought my 110 amp alternator from Schucks for about $135. They want twice that at normal shops? Or were you pricing the dealership? Install was pie, just bolt it in, connect the wire, and tension the belt. (pry bar to add tension, wrenches to tighten in place, it was a 2 person job)
The TPS should be at the throttle body on the intake.
post #7 of 7 Old 12-29-2001, 03:05 PM Thread Starter
Big Dumb White Guy
had AZ check my altenator and battery today. alt is bad. got new on the way..... AZ wanted $147 for 90 amp model. see above...
repost Nazi's suck!
