Who's rear trackbar do i want? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Who's rear trackbar do i want?
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-17-2011, 10:38 PM   #1
ExpeditionXJ
Have most items i need to lift my 98 ZJ, minus a rear trackbar and crossmember for my front radius arms. Coming from the XJ world, so rear TB's are new to me.
This is not a hard wheelin rig, mostly interstate and two tracks to remote scenic camps. I dont like heims on suspension components and adjustability/rebuildable is high on the list. I want something thats gonna hold up. Lift height is gonna be 4.5-5" with rear short arms till i scrape up the coin for a triangulated LA rear.
What holds up.. what do i stay away from?
ExpeditionXJ is offline   Reply With Quote Quick reply to this message
Unread 06-17-2011, 10:44 PM   #2
1stblack97ZJ
Probably the two rear track bars that I see most used on this forum (on ZJs), are the IRO adjustable, and the JKS adjustable.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline   Reply With Quote Quick reply to this message
Unread 06-17-2011, 11:05 PM   #3
ExpeditionXJ
OK, thanks. I see the diff between them is the IRO is solid 1.25" vs the hollow but probably stout 1.25" JKS, the IRO looks to have a few more bends in it.. any advantage there?
Both look to be $140ish.. neither needs a bracket kit?
Unread 06-18-2011, 12:02 AM   #4
ratmonkey
R.I.P.
ratmonkey's Avatar
Solid tube does not resist bending forces any better than hollow tube of the same diameter.
Bends are for clearance.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 06-18-2011, 07:28 AM   #5
ExpeditionXJ
Those with the JKS TB.. the JJ rebuild kits, are they the same as RE's TB and smaller control arms? Be nice if i can use the same kit and tool to service.
Unread 06-18-2011, 07:36 AM   #6
biebs53
I don't know much about the JKS TB but the IRO is nice. They had some contact issues but they redesigned it recently and they fit perfect now and don't contact anywhere. If you have stock exhaust, any TB might hit it while flexing. I know mine looked close to the exhaust so I dumped it before the rear axle.
[CENTER][FONT="Franklin Gothic Medium"]1998 Jeep Grand Cherokee 5.9 Limited
Build thread: [url]http://www.jeepforum.com/forum/f197/project-raven-biebs53-build-thread-1215245/[/FONT][/url][/CENTER]
biebs53 is offline   Reply With Quote Quick reply to this message
Unread 06-18-2011, 08:12 AM   #7
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
if you need a rear track bar, PM me, i have the one from my old lift for sale.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 06-18-2011, 09:26 PM   #8
KingtheZJ
the IRO is better. it uses regular polly bushings which are easier to find and cheaper. and the bends clear the diff and exhaust better.
'98 ZJ on 37s and tons
'97 Cummins 2500
KingtheZJ is offline   Reply With Quote Quick reply to this message
Unread 06-18-2011, 09:49 PM   #9
TallyZJ
I like my IRO front track bar but I am questioning the durability of the poly bushings. Think I am gonna get a set of super hard durometer type.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
Capital City Jeepers
Build Thread Here
TallyZJ is offline   Reply With Quote Quick reply to this message
