Whoops! (Pics) - Page 2 - JeepForum.com
post #16 of 21 Old 02-10-2013, 04:07 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Ok I got the toe in set with the bar I have, I don't think the tie rod is actually bent, apparently the 4.0 has a smaller perfectly straight tie rod and the V8 has a beefier one with bends in it. I was a little out of toe but once I go it back in it felt no different. Steering seems tight, and I just have no idea what else to check. Any ideas?
kg6mov is online now
post #17 of 21 Old 02-10-2013, 04:10 PM
Oldfrog
2007 WK
Mine did that a 1/2 mile from home in a residential area. Not fun trying to turn.....trust me. Nearly impossible, but do-able. It simply broke. No wreck, no nothing. I creeped home turning my steering wheel way farther than usual just to make it around the few corners needed to get home. Scary.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #18 of 21 Old 02-10-2013, 09:03 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Any help?
post #19 of 21 Old 02-10-2013, 09:25 PM
ElCaminoManT
check the wheel that took the hit
1993 Jeep ZJ Laredo 4.0L/42RE/242/D30/D35
ElCaminoManT is offline
post #20 of 21 Old 02-10-2013, 11:31 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Tried swapping the wheel that took the hit for the spare, no difference.
post #21 of 21 Old 02-11-2013, 01:35 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
check the mounts for the track bar, check the control arms, you've got death wobble now.
ratmonkey is offline
