Whoops! (Pics) - JeepForum.com
post #1 of 21 Old 02-08-2013, 01:24 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Whoops! (Pics)
So this happened,
Pulling in to work, tried to avoid hitting a blind woman driving a camry and hit a curb pretty much sideways with the front right wheel.
Was driving to another building and damn the steering feels looser than usual. And the bad cv joints should make it shake like that!
Grabbed the floor jack out of the supply cabinet popped the front end up a little to have a look. Noticed the track bar mount on the frame, shouldn't something be connected to that?
Track bar was resting between the tie rod and the pumpkin, grabbed the socket set from the cabinet, pulled it completely.
I have -290 points.
-300 for breaking a suspension component in a parking lot.
+10 for breaking one I have a spare of.
Theres a brand new JKS adjustable track bar (thanks kolak!) sitting in my garage waiting to go in with the rest of the lift, I'm assuming I'll be able to get it set right for a stock suspension, it would be a shame to have to put in the rest of the lift just to fix a track bar
Home is about 10 miles away, can I take it slow and get there or am I best off just calling a tow?
kg6mov is offline
post #2 of 21 Old 02-08-2013, 01:29 PM
Montaska
Montaska's Avatar
2016 KL Cherokee
Nevermind haha. My iphone didn't load the text and I thought your jack failed.
2016 Cherokee KL Latitude ADI
- 1.5" MFC Lift
- 245/70R17 Cooper Discoverer A/T3
1997 ZJ: Sold | 2002 WJ: Sold | 2007 JK: Sold | 2016 KL: Current
Montaska is offline
post #3 of 21 Old 02-08-2013, 01:37 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
how fun was driving that?
ratmonkey is offline
post #4 of 21 Old 02-08-2013, 01:40 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Was great, with my boss and my floor manager in the car too. The floor manager bought his son a zj and wanted to show the kid my steering to make him stop complaining.
kg6mov is offline
post #5 of 21 Old 02-08-2013, 01:52 PM
KJK
I'd check the runout on that right front wheel! A hit like that might have tweaked it a fair bit.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #6 of 21 Old 02-08-2013, 06:01 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
breaking that stud takes some effort. i'd check over everything on that front axle.
do NOT drive that on the road at all.
post #7 of 21 Old 02-08-2013, 06:03 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Yep, tow truck is gonna take it home and I'm gonna go to o'reilly and get new cv shafts and tear the whole front end up.
kg6mov is offline
post #8 of 21 Old 02-09-2013, 07:06 AM
fljeepney
Stupid Toyota drivers!!!
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
1985 Corolla AE86 coupe
fljeepney is offline
post #9 of 21 Old 02-09-2013, 09:13 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Got the track bar fixed, PITA to get the sheared bolt out. Doing the cv axles now since they needed it and contributed to hitting the curb. Will know more once those are done but my steering wheel is about 45 degrees to the left of center, what else could I have f'ed up?
kg6mov is offline
post #10 of 21 Old 02-10-2013, 10:47 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Drag link and tie Rod are likely bent.
post #11 of 21 Old 02-10-2013, 11:08 AM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Will check those, it wasn't driving too bad yesterday with the new track bar. This morning I've suddenly got vibrations from hell, front end starts to vibrate once I get up to 30 or so and it keeps shaking till I come to a full stop. It was vibrating a little at highway speeds yesterday but I could accelerate through it. Not really interested in trying that today.
kg6mov is offline
post #12 of 21 Old 02-10-2013, 11:13 AM
skip11and1
2013 MK Patriot
alignment and wheel balnce done?
2013 Jeep Patriot 4x4 FD1 5spd
2004 R6 lowered, stretched, full exhaust, HIDs etc
2004 TJ Columbia package long armed w/ 33's (Sold)
2005 WK, v6 QT1 (girlfriends)
skip11and1 is offline
post #13 of 21 Old 02-10-2013, 11:37 AM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Ha, toe in is 1", shoulda checked that sooner, but I was trying to get to work on time today, so much for that idea. Do I need to get the wheels balanced? I didn't change anything with them, and it doesn't loot like I knocked off a weight. I'm running severely low on $$ with the niner getting new innards, I had to give my mechanic some parts money so he could get the transmission, and now I have all of like $350 until payday.
kg6mov is offline
post #14 of 21 Old 02-10-2013, 11:43 AM
durango-bob
2006 WK
Check the axle control arm mounts. A hit like that can easily bend the lower mounts or even damage the control arms. Also, depending on the amount of lift, the right side upper control arm mount on the axle can be driven into the side of the oil pan and it can even break the oil pump inside. (Don't ask me how I know this) I would also take a good look at the ball joints and the knuckle on that side. I suspect that you find additional damage once you dig into it. And pics are always fun for us couch potatoes.
durango-bob is offline
post #15 of 21 Old 02-10-2013, 11:53 AM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
I'm assuming the tie rod should be straight and not look like this:
Or this:
The ball joints and the knuckles looked ok, but I don't have anything to compare to, I'll toss the tie rod and drag link and update. How can I check the knuckles and ball joints? I shook them when the wheel was off and it felt ok. CA's look ok too and it doesn't look like they hit anything.
kg6mov is offline
