06-23-2007, 09:21 PM
#1
whole front axle shaft or just outer shaft?
CV joint on drivers side axle is torn, throwing grease all over and has developed a clicking, so I figure its time to replace it all.
Found Arlos write up, looks pretty easy. Just one question...
When I get the parts, is it the the entire driver side inner/outer shaft and cv joint?
Any pointers for this job that arent in Arlos write up?
Thanks
-Adam
His: 2000 WJ, 2.5" BB, mx-6 shocks, Rancho 5000 Steering Stabilizer, 245/75/16 MTRs, 1" addco rear sway bar, 9005 fog upgrade
Hers: 03 KJ, 5-speed, 245/70/16 General HTS
WTB: 1 Timberline wheel or a set of JK steelies
06-23-2007, 09:32 PM
#2
I ate what?
its just one shaft per side. there is no inner and outter shaft. You have the driver and the passenger cv half shaft. Here's a link, if you have quadra drive it will be a different one, they are the cheapest you can find anywhere and they are beefier than stock.
http://cgi.ebay.com/ebaymotors/CV-AX...spagenameZWDVW
This may not be the one you need, but just check his store and you will find the correct one.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
06-23-2007, 09:37 PM
#3
Thanks for the info and link Ken.
So that will go all the way to the diff then?
-Adam
06-23-2007, 09:50 PM
#4
I ate what?
Yep, its one piece.
Very easy install, and with those prices, it's definitely easier than just changing the rubber boot. Not to mention once there is a rip in the boot the CV joint can degrade much quicker. Check the other one too and make sure it's not dry rotted and cracking as well. Even if it's not it wouldn't hurt to change both sides and then keep the good one you took out as a trail spare...That's what I did.
Ken
2006 Pontiac G6 GTP
06-23-2007, 10:05 PM
#5
awesome, thanks Ken!
-Adam
06-24-2007, 07:21 AM
#6
Jeep Jedi Master
Arlo's write up is very easy to follow.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
06-24-2007, 07:57 AM
#7
