White Smoke...Sometimes? - JeepForum.com
post #1 of 4 Old 05-03-2013, 09:02 PM Thread Starter
CanaanTSA5
Every once in a while within the last 2 months I get white smoke coming from my exhaust when I start up my Jeep. Out of the times it's done it (about 4), each has been a bit different in the amount (or density) of the smoke. The first times was the worst.
I know I burn coolant. It's not steady though. I check it every week, sometimes about 2 inches is gone, sometimes none. Doesn't seem to be time related to the exhaust smoke though..
It doesn't run any differently when the smoke issue happens, it's a little choppy to begin with because she needs new mounts. The smoke usually goes away within 3 minutes.
Any ideas..?
1998 ZJ 4.0 Stock 225/75R15 General Grabber AT2
191,000mi
CanaanTSA5 is offline
post #2 of 4 Old 05-03-2013, 09:11 PM
JasonStebbins
Could be the head gasket starting to fail, especially since you said you're losing coolant. Is the oil milky? Does your coolant reservoir bubble?
Could be a bad catalytic converter.
Could be condensation.
Poop
JasonStebbins is offline
post #3 of 4 Old 05-03-2013, 09:28 PM Thread Starter
CanaanTSA5
No milky oil. No bubbling. Once in a blue moon when I start it up I get an engine knock. But that's 1 every 400 times I start it. It does it about 7 times and then goes away. About 3 knocks per second. I figured just my POS PCM acting up like it loves to do.
191,000mi
post #4 of 4 Old 05-03-2013, 09:40 PM
JasonStebbins
My 4.0L has the "cold start" knock every time. People look at it like it's going to blow up, but it's done it for two and a half years. Goes away once it warms up. I assume it's piston slap or the transmission flex plate.
It's probably just condensation or old converter.
Poop
