Whining while accelerating, coming from rear. ?? - JeepForum.com
post #1 of 8 Old 01-10-2014, 10:44 AM Thread Starter
Rboomer
My 98 limited ZJ whines when I'm accelerating from about 25-55 mph I'm thinking 2nd up to 5th gear. It's loudest is about 45mph and is pretty quiet when I'm doing 70mph. The sound comes from the rear of the car. Not totally sure if it's my fluids, axle, or tranny bearings. Fluids are topped off and haven't done anything else to check what it could be. Would love some input. Thanks
Rboomer is offline
post #2 of 8 Old 01-10-2014, 11:55 AM
JasonStebbins
Four speed transmission. You're mistaking overdrive as the fifth gear.
Whining/moaning is usually a sign of bad pinion/carrier bearings in the differential. When is the last time you changed the gear oils?
Poop
JasonStebbins is offline
post #3 of 8 Old 01-10-2014, 12:51 PM Thread Starter
Rboomer
It's been a long time for sure since I changed gear oil.
Rboomer is offline
post #4 of 8 Old 01-10-2014, 01:11 PM
JasonStebbins
Probably why the bearing failed due to poor lubrication. Once it's bad there's not really much you can do, but changing the fluid can sometimes alleviate it and extend what's left of it's life.
How many miles on it?
Poop
post #5 of 8 Old 01-10-2014, 01:20 PM Thread Starter
Rboomer
157000
Rboomer is offline
post #6 of 8 Old 01-10-2014, 01:50 PM
Oldfrog
2007 WK
If only when accelerating, it's probably the pinion bearing.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #7 of 8 Old 01-10-2014, 02:00 PM
riot1987
I vote on pinion/carrier/axle bearings. ESP if you havent peeked inside your differential for some time
Build thread^^
riot1987 is offline
post #8 of 8 Old 01-10-2014, 04:48 PM Thread Starter
Rboomer
Thanks for the feedback guys!
Rboomer is offline
1998 jeep grand cherokee , whining noise , zj
