Whining sound in front wheel at speed - JeepForum.com
post #1 of 11 Old 10-08-2009, 12:50 PM Thread Starter
Rushkiboy
I'm getting a whining sound coming from the front passenger side wheel when I get to 10+ mph. At slow speed in almost sounds like an unbalanced whine (you can tell its not the full rotation, skipping sound). Obviously the faster I go the louder and more continueous it sounds. What do you guys think? Thanks.
Rushkiboy is offline
post #2 of 11 Old 10-08-2009, 12:52 PM Thread Starter
Rushkiboy
Oh and by the way its an 2004 Grand Cherokee 4X4 w/4.0L. Select trac.
post #3 of 11 Old 10-08-2009, 04:29 PM
MylesNT
I vote wheel bearing....that's just my guess...
-MNT
Black '96 4.0
IRO 3.5" with Adj LCAs
Dana 30 Locked, Dana 35 Detroit Truetrac, 4.56s
Alabama Jeepers
Black Jeep Society
MylesNT is offline
post #4 of 11 Old 10-08-2009, 05:02 PM
oldfamilyguy
I would suspect wheel bearing too. Get on some open road where you can turn the steering wheel a bit while you're rolling. The bearing noise should change as you put and take away different load on it.
oldfamilyguy is offline
post #5 of 11 Old 10-08-2009, 05:16 PM
cmonson
wheel bearing or CV. I would vote wheel bearing 1st. Could be front diff, but I highly doubt it. Front diff usually starts whining at higher speeds and deffinately does not sound like an unbalanced tire.
Nice thing is the hub bearing is very easy to change on our cars.
cmonson is offline
post #6 of 11 Old 10-08-2009, 05:39 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
Jack up the wheel and look for play. Also inspect the CV joint, see if the boot is torn etc. Then report back to us.
WALTER
walter_da_jpr is offline
post #7 of 11 Old 10-09-2009, 02:12 PM Thread Starter
Rushkiboy
Ok thanks for the responses. Whats a CV joint? and where is it? Whats it look like? The dealer by me (McDonaugh Jeep, East Brunswick, NJ) has the wheel bearing hub assembly for $290.00 each. I need the whole assembly because the bearings are sealed right? I think I saw aftermarket and better quality for much cheaper, not sure if it was my model that I saw though. Can anyone recommend a place & brand to buy from? Thanks again for the responses.
post #8 of 11 Old 10-09-2009, 03:55 PM
MylesNT
The CV joint is part of the Front drive shaft. And it is basically a ball and socket. I'm not real sure about your wheel bearing becaus yours is pretty new. One on my 96 was like $50. Most folks here know more than me. Somebody can probably give you a better answer.
-MNT
Black '96 4.0
Alabama Jeepers
Black Jeep Society
MylesNT is offline
post #9 of 11 Old 10-09-2009, 04:31 PM Thread Starter
Rushkiboy
Don't know anything about the CV. I called around and found wheel bearing hub assembly for $104 each ($125 for "premium") at NAPA auto parts store by me, in stock. Not the $290 each the stealership wanted. My 2004 Grand Cherokee does have 91,000 miles on it.
post #10 of 11 Old 10-09-2009, 05:14 PM
MylesNT
Wait...I'm talking about a different CV joint..ignore what I said about the CV.
-MNT
Black '96 4.0
Alabama Jeepers
Black Jeep Society
MylesNT is offline
post #11 of 11 Old 10-12-2009, 11:29 AM Thread Starter
Rushkiboy
Thanks to all who helped, did the hub replacement this weekend and everything is good.
ZJ front end loud rattle increases with wheel speed. MurdaJs ZJ Grand Cherokee Forum 3 10-16-2009 11:28 PM
Whining sound from front driver side wheel Bubbles ZJ Grand Cherokee Forum 2 08-06-2009 09:06 AM
Whining from front left wheel salsa ZJ Grand Cherokee Forum 8 06-09-2009 02:07 PM
Whining noise, dependent on wheel speed? jasonodle ZJ Grand Cherokee Forum 4 02-07-2009 02:39 PM
Sound from front left wheel cdn96zj ZJ Grand Cherokee Forum 1 06-10-2006 10:48 AM
