Whining noise, dependent on wheel speed? - JeepForum.com
post #1 of 5 Old 02-06-2009, 07:38 AM Thread Starter
jasonodle
My 2004 Grand Cherokee has started to whine. From very low speeds all the way up to high speeds. It is dependent on wheel speed, not engine speed. It sounds like it is coming from the front of the vehicle.
Any suggestions on what to check for?
jasonodle is offline
post #2 of 5 Old 02-06-2009, 08:09 AM
JG_Canuck
Can you be more specific? Does it change when accelerating vs coasting? Does it go away if you float the throttle while cruising?
Could be pinion noise...
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #3 of 5 Old 02-06-2009, 08:45 AM Thread Starter
jasonodle
Yes, changes pitch when accelerating. Does go away when you float the throttle, it is wheel speed related, not engine speed.
Pinion noise?
post #4 of 5 Old 02-06-2009, 08:56 AM
limited_pit
Front diff bearings
just did mine HAD! the same problem
94 Ta A4 (my summer project)
97 ZJ TSi 5.2
B5 VW (wifes car)
limited_pit is offline
post #5 of 5 Old 02-07-2009, 02:39 PM
electrician
i have the same prob with my 2000 zj quadradrive, i've been driving it for a month like this now and it hasn't got any worse. will it get worse??
i took it to a few mechanics they said its the diff. one told me he wants to replace the whole thing, is that a good idea? i'd rather keep it as original as i can as i don't trust a rebuilt diff, cuz it mite happen again soon...
the noise mine makes starts as 30 km/hr like yours and it whines and as i get up to about 60 km/hr, the whining sorta rattles, and as i let go of the gas and decrease in speed, the whining sounds like its winding down as opposed to how its winding up as i go past 30...maybe someone can diagnose from that if my case is cracked or its just something inside the case?
electrician is offline
Whining sound in front wheel at speed Rushkiboy ZJ Grand Cherokee Forum 10 10-12-2009 11:29 AM
Another day, another noise - whining noise while accelerating and slowing swataz ZJ Grand Cherokee Forum 8 12-11-2008 09:05 PM
whining noise gebster WK Grand Cherokee & XK Commander Forum 15 05-16-2008 06:39 AM
cherping noise/whining noise coming from passanger side LoweBudget ZJ Grand Cherokee Forum 0 12-06-2002 11:10 AM
97 Zj Whining Noise JAYMAN97ZJ ZJ Grand Cherokee Forum 3 12-01-2002 01:56 PM
