Where are your extra lights mounted? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Where are your extra lights mounted?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ Ch
Unread 09-08-2014, 04:04 PM   #1
neverXalone
Had mine on top of my roof rack, I think if you click on my profile you can see the pics. But i took them off so i can fit my kayaks up there, and because its my DD and its a PITA not being able to fit into parking garages. So where else is good besides ontop to put these? I have 4 6in 100 watt KC daylighters.
95 ZJ I6
FHRITP
neverXalone is offline   Reply With Quote
Unread 09-08-2014, 05:32 PM   #2
bskool
could you remove your wind faring and put them under the top bar? Aside from that, get a light bar for your bumper but that's a lot of lost airflow to your radiator. edit. mine are under the top bar on a homemade rack so my kayaks don't hit it.
98 ZJ 5.2, custom bumper and rocker panels, moog steering and suspension, 2" BB , 31/10.5R15 ATs
bskool is offline   Reply With Quote
Unread 09-08-2014, 05:54 PM   #3
kg6mov
Hears the voices
kg6mov's Avatar
I like my a pillar mounts.
I've seen some good looks mounting them behind the grill, but not with the bigger halogens. Get the factory fog brackets from a JY if you don't have lights there already. I also have LED fogs in my bumper.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is offline   Reply With Quote
Unread 09-08-2014, 05:59 PM   #4
underpowered
Bouncin' on a Budget
underpowered's Avatar
on the bumper. i'd rip em off on the roof.
1998 ZJ 2" bb and 31's. street queen but sees the woods once in a while.
2000 powerjoke tow pig
Anti-jeep--1989 K5 blazer. the new off road ride
underpowered is offline   Reply With Quote
Unread 09-08-2014, 06:07 PM   #5
gearheadnick
I have mine mounted on a safari bar in front of the bumper. They're tougher than people give them credit - I've had it put to the test. You could put 4 lights on it if you added a bracket to the mounting points.
My cylinder head overhaul: http://www.jeepforum.com/forum/f13/cylinder-head-r-r-picture-heavy-1348138/
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline   Reply With Quote
Unread 09-08-2014, 06:26 PM   #6
Jeepzj916
I got a 20" led light bar mounted to my brush guard
93 ZJ with 4.0 i6, aw4 trans, and np249 tcase
Jeepzj916 is online now   Reply With Quote
Unread 09-08-2014, 10:08 PM   #7
neverXalone
can you post a pic of your set up? sounds like something that could work for me.
Also, i just have the oem plastic bumper. Do you guys that suggested the bumper mounts have the oem bumper, or steel?
Edit: Nevermind I didnt realize you were the same poster that i already commented on your thread about how much i loved your roof rack that you built. There isnt enough room for me to put them underneath the top bar on mine. But EVERYONE ELSE post pics of your set ups. I thinking about going with these pillar mounts from detours for two and doing the other two on the bumper.
95 ZJ I6
FHRITP
Unread 09-08-2014, 10:58 PM   #8
kg6mov
Hears the voices
kg6mov's Avatar
The a pillar light mounts are easy to make.
The first gen factory fog mounts should be easy to find.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread 09-08-2014, 11:52 PM   #9
ElCaminoManT
i have my 2 4" HIDs mounted up front. i pretty much attached them how the factory 93-95 fogs are attached from the factory, i think (ive never really looked at the factory mounts, but it looks like the similar position. they work great, but i do plan to put some light up top eventually
1993 Jeep ZJ Laredo 4.0L/42RE 242 4x4. 3" springs. Front and rear RC tubular lowers. Rusty's adjustable rear uppers. RE double-sheer front track bar. JKS adjustable rear track bar. Bilstein 5100s. 31" Falken Rocky Mountain A/T. 15" Eagle wheels. V8 steering linkage.
ElCaminoManT is offline   Reply With Quote
Unread 09-09-2014, 01:07 AM   #10
neverXalone
I found with having lights up top, if my windshield wasn't completely clean then I would get an awful glare and I would have trouble seeing.
95 ZJ I6
FHRITP
Unread 09-09-2014, 05:06 AM   #11
AnotherRedZj
5.2 crate - fourwheelcustoms 2.25 BB - 31x10.50 BFG at-ko's 249/242 swap - front drive shaft upgrade by driveshaftspecialistincorporated - jcr off-road front bumper - engo 12k lbs winch......
AnotherRedZj is offline   Reply With Quote
Unread 09-09-2014, 07:35 AM   #12
Foster1
I have 2 KCs mounted on my brush guard in front of the grille.. never noticed any differences in temperature. They were really easy to route and converge nicely being up front and close together. Before these I had a set of el-cheapos in the same place and used my factory fog light pigtail to run them..
Foster1 is offline   Reply With Quote
Unread 09-09-2014, 04:14 PM   #13
underpowered
my 95 had the factory fog lights and they work well with the stock bumper.
my 98 has a tube bumper
Unread 09-09-2014, 05:42 PM   #14
sadass
sadass's Avatar
ProtofaB winch bumper. no reflection from the hood up there, good and High but not up in the over hanging branches so they see little to no trail carnage.
Military Jeepers.Com.
Jeep Forum member since 2/2002
5Nine=No replacement for Displacement
sadass is offline   Reply With Quote
Unread 09-09-2014, 11:15 PM   #15
neverXalone
"Custom Fabricated" some brackets at work today, meaning I hacked up a pair of stainless steel mounting brackets that we had laying around the shop that once went to an older model of Thule rooftop storage bin. I think theyll be strong enough with a little more fabrication (hacking). I mounted them on the two bolts that sit just between the grill and the bumper cover as someone suggested. Metal work is not a strength of mine. Ill post a picture of what i did in the morning.
95 ZJ I6
FHRITP
