where is the speedometer gear!!! - Page 2 - JeepForum.com
post #16 of 22 Old 09-21-2009, 06:45 PM Thread Starter
wjchristine
my temp gauge doesn't say it is not over heating at all when its idling or when im driving?
wjchristine is offline
post #17 of 22 Old 09-22-2009, 06:52 AM
rm2001wj
rm2001wj's Avatar
That code indicates that the engine computer (PCM) thinks the signal voltage from the engine coolant temp (ETC) sensor is too high. That sensor going bad is not common, but the fix is to replace the sensor. If you want to do it yourself, the attached diagram could help you locate it. The MAP sensor is on the front of the intake manifold below and between the alternator and AC compressor. The ECT sensor is a little below the MAP sensor. The diagram is a little confusing because the alternator and AC compressor have been deleted for clarity.
rm2001wj is offline
post #18 of 22 Old 09-22-2009, 02:20 PM Thread Starter
wjchristine
do i need to to replace both sensors
post #19 of 22 Old 09-22-2009, 04:09 PM
rm2001wj
rm2001wj's Avatar
Just the ECT sensor. I mentioned the MAP only to help locate the ECT, because it will be a little easier to see the MAP when the compressor and alternator are in their normal positions.
rm2001wj is offline
post #20 of 22 Old 09-22-2009, 04:20 PM Thread Starter
wjchristine
ok i will do that and get back to you.
post #21 of 22 Old 09-26-2009, 10:52 AM Thread Starter
wjchristine
thank goodness. i fixed the coolent issue. thank you for you help.
post #22 of 22 Old 09-26-2009, 04:19 PM
urq2
urq2 is offline
Need a reasonably priced speedometer gear supplier. Brian's 97 ZJ ZJ Grand Cherokee Forum 2 09-03-2009 04:40 PM
Speedometer pinion gear ryandavenport ZJ Grand Cherokee Forum 5 04-23-2009 06:55 AM
Speedometer tire/gear chart jeepejeep ZJ Grand Cherokee Forum 0 02-25-2006 10:44 AM
Does WJ have Speedometer Gear ??? CinciSurWJ ZJ Grand Cherokee Forum 5 08-16-2005 04:46 PM
Where is my speedometer gear??...It's gone!!! James77 ZJ Grand Cherokee Forum 2 06-04-2002 09:37 AM
