where is the speedometer gear!!! - JeepForum.com
post #1 of 22 Old 09-20-2009, 10:18 AM Thread Starter
wjchristine
my speedometer decided to stop working along with my odometer, cruise control, and over head gauges. the speedometer will randomly come on and then all the other things work to but then it will cut off randomly and everything will stop. my CHL is on and it says the rear speedometer needs to be replaced. i looked on my trans and there was no place for the gear. i asked a local shop and they said it is in the axle and i cant find it there either. is there anyone that might know how to fix this weird problem?
wjchristine is offline
post #2 of 22 Old 09-20-2009, 10:21 AM
XJMuscle98
speedometer gears are on the transfer case
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #3 of 22 Old 09-20-2009, 10:29 AM Thread Starter
wjchristine
sorry i meant to say the transfer case. i looked and even got the dealership to look and they could locate it either.
post #4 of 22 Old 09-20-2009, 10:43 AM
BigDaveZJ
Not on WJ's. The WJ's pull their speedo info from the ABS tone rings on the axle shafts.
95 ZJ with lots of stuff
14 WK2
BigDaveZJ is offline
post #5 of 22 Old 09-20-2009, 10:45 AM
rm2001wj
rm2001wj's Avatar
What is "CHL" in your phrase "my CHL is on"?
WJs don't have a speedometer gear. The PCM in WJs use the wheel speed sensors to generate the speedometer reading.
Edit: Post #4 beat mine, but I will just leave it up.
rm2001wj is offline
post #6 of 22 Old 09-20-2009, 10:59 AM Thread Starter
wjchristine
well im an idiot. i meant CEL, check engine light. sorry about that. i never knew exactly where to fix the problem because i have never had this problem or heard of it. this guy at a local jeep dealership told me it was on the transfer case. well how do i got about fixing it cause i really don't wanna get a ticket?
post #7 of 22 Old 09-20-2009, 01:55 PM
rm2001wj
rm2001wj's Avatar
Since the gauges are acting up, you problem might be electrical and have nothing to do with the wheel speed sensors. In order to go any further more info is needed. Retrieve the trouble codes using the key on/off method. It goes like this,
Turn the ignition key until the digital odometer displays, repeat two times in succession and then back to "On" (On/Off, On/Off, On). At the third "On" the odometer reading will be replaced with codes. If no codes are present then "donE" will appear.
The codes will have the form P0xxx and/or Pxxxx. Post any numbers that you get.
After that, disconnect the battery cables, and make sure that the cable connectors and battery terminals are clean and free of corrosion. Disconnecting the battery will usually erase any codes. Start back up and see if the CEL comes back on. Whether it does of not, retrieve (using the above procedure) any codes and post the numbers again.
BTW, you can use the tach displaying engine rpms to get pretty good numbers for the vehicle speed when in 4th gear.
rm2001wj is offline
post #8 of 22 Old 09-20-2009, 02:30 PM
XJMuscle98
opps, wrong forum... sorry.
Ronald Reagan
Currently: 10
post #9 of 22 Old 09-20-2009, 04:22 PM Thread Starter
wjchristine
ok sweet i got the codes. when i did the ignition thing the first time i got the code: P 0118 and P 0500. i cleaned the post and did the ignition thing again and i got donE. Now what boss?
post #10 of 22 Old 09-20-2009, 06:03 PM
tsconver
2003 WJ
118 is a coolant temp sensor issue unrelated but get it fixed
500 is a no speed sensor signal issue
P0500-NO VEHICLE SPEED SIGNAL
When Monitored: Engine Temperature greater than 104 deg F. , MAP vacuum approximately
159 to 169 inches of mercury and Engine RPM between 1400 and 3000 rpm.
Set Condition: No Vehicle Speed Signal for more than 15 seconds on two consecutive
trips.
Is your abs light on? If not then you have issues with either your wiring between the abs computer and the PCM or the PCM itself.
Here is the troubleshooting guide from the FSM
1 Ignition on, engine not running.
With the DRBIIIt, read DTCs and record the related Freeze Frame data.
NOTE: Any VSS DTCs in the CAB Module or Body Controller must be
properly diagnosed before continuing.
Is the Good Trip Counter displayed and equal to zero?
All
Yes ! Go To 2
No ! Refer to the INTERMITTENT CONDITION Symptom (Diagnostic
Procedure).
Perform POWERTRAIN VERIFICATION TEST VER - 5.
2 Turn the ignition off.
Disconnect the PCM harness connectors.
Disconnect the ABS Control Module harness connector.
Measure the resistance of the (G7) Vehicle Speed Signal circuit between the PCM
harness connector and the ABS Control Module harness connector.
Is the resistance above 5.0 ohms?
All
Yes ! Repair the open in the (G7) Vehicle Speed Signal circuit.
No ! Go To 3
3 Measure the resistance between ground and the (G7) Vehicle Speed Signal circuit at
the PCM harness connector.
Is the resistance below 100 ohms?
All
Yes ! Repair the short to ground in the (G7) Vehicle Speed Signal
circuit.
No ! Go To 4
DRIVEABILITY - GAS
TEST ACTION APPLICABILITY
4 Ignition on, engine not running.
Measure the voltage on the (G7) Vehicle Speed Signal circuit at the PCM harness
connector.
Is the voltage above 4.8 volts?
All
Yes ! Repair the short to voltage in the (G7) Vehicle Speed Signal
circuit.
No ! Go To 5
NOTE: Turn the ignition off before continuing.
5 NOTE: Before continuing, check the PCM harness connectors for corrosion,
damage, or terminal push out. Repair as necessary.
Using the schematics as a guide, inspect the wire harness and connectors. Pay
particular attention to all Power and Ground circuits.
If there are no possible causes remaining, view repair.
All
Repair
Replace and program the Powertrain Control Module per Service
Information.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #11 of 22 Old 09-20-2009, 06:32 PM Thread Starter
wjchristine
well the light isnt on. so now i will try to accomplish this. i was really afraid of an electrical problem. thank you for the help. i will try to knock this out within the next two days.
post #12 of 22 Old 09-20-2009, 08:08 PM
rm2001wj
rm2001wj's Avatar
Did you start up the engine before retrieving the codes the 2nd time? Actually, driving it some would be better. If you have no codes and the CEL is not on, you should be good to go.
rm2001wj is offline
post #13 of 22 Old 09-21-2009, 03:50 PM Thread Starter
wjchristine
no i didnt start it before hand. the CEL went off but then after driving it the light came back on.
post #14 of 22 Old 09-21-2009, 06:12 PM
rm2001wj
rm2001wj's Avatar
Have you been in the mud lately. Mud can cake on the tone rings and/or wheel sensors and cause them to give no or erratic signals. If that's not the problem, then it looks like you will have to take it to the dealership so that it can be properly diagnosed. The P0500 doesn't really give enough info.
rm2001wj is offline
post #15 of 22 Old 09-21-2009, 06:40 PM Thread Starter
wjchristine
no i havent been in the mud at all so i guess ill have to take it to the stinkin dealership. thank you very much for the help. i iwll keep you posted. you wouldn't happen to know anything about the coolant sensor issue would you?
Need a reasonably priced speedometer gear supplier. Brian's 97 ZJ ZJ Grand Cherokee Forum 2 09-03-2009 04:40 PM
Speedometer pinion gear ryandavenport ZJ Grand Cherokee Forum 5 04-23-2009 06:55 AM
Speedometer tire/gear chart jeepejeep ZJ Grand Cherokee Forum 0 02-25-2006 10:44 AM
Does WJ have Speedometer Gear ??? CinciSurWJ ZJ Grand Cherokee Forum 5 08-16-2005 04:46 PM
Where is my speedometer gear??...It's gone!!! James77 ZJ Grand Cherokee Forum 2 06-04-2002 09:37 AM
