Where is the Power Door lock Relay/Module - JeepForum.com
post #1 of 8 Old 10-29-2010, 08:51 PM Thread Starter
needspeed
I'm still trying too figure out why my power locks won't lock on my GC, I was thinking about replacing the modules or relays now. Nothing else has worked.
needspeed is offline
post #2 of 8 Old 10-29-2010, 08:58 PM
ZeJokee
are they not working all together, intermittently, or just unlocking but no locking?
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #3 of 8 Old 10-29-2010, 09:29 PM Thread Starter
needspeed
If I lock everything manually they will unolck when I push the switch to unlock on the drivers door. But they will not lock when I push the switch to lock, except the driver door it works fine, some of the actuators sound like they are trying to lock but the don't.
post #4 of 8 Old 10-30-2010, 07:19 AM
jeep210
I beleive there is a relay center below the glove box. It is on the right side of the box. I have never looked for it. It has the door lock, door open and interior illumination relays as I recall. I cannot open the file that has a drawing.
If the drivers door works, it may be a wiring problem. Many have had problems with the wiring harness where it goes in from the drivers door to the vehicle cab. The flexing of the harness causes some wires to break.
jeep210 is offline
post #5 of 8 Old 10-30-2010, 07:29 AM Thread Starter
needspeed
I have been wondering about a wireing problem too, I checked the wires betwee the door and cab, If its a wire problem I'll have to set a side a few days to do some wire tracing. Thats why I am trying to replace the easy stuff first. But that is starting to get expensive.
post #6 of 8 Old 10-30-2010, 11:49 AM
tcar
Originally Posted by needspeed View Post
I have been wondering about a wireing problem too, I checked the wires betwee the door and cab.
It sounds like a broken wire there, that may be making intermittent contact.
Very, very common problem.
Pull back the rubber accordian boot and look. The wire may look OK if you don't look closely, and the insulation may be almost intact with a broken wire inside.
It's an easy fix (awkward, though) with wire connectors.
tcar is offline
post #7 of 8 Old 12-28-2014, 06:16 PM
sholcomb
My power locks will un lock but won't lock where is the relays at on a 2010 jeep wrangler unlimited jk
sholcomb is offline
post #8 of 8 Old 12-28-2014, 06:25 PM
AnotherRedZj
Probably some where in the JK technical forums
AnotherRedZj is offline
Power door lock motors work but no lock! lasvegas ZJ Grand Cherokee Forum 2 10-25-2009 12:29 PM
Drivers Door Window/lock module not working twisted_ed ZJ Grand Cherokee Forum 6 05-07-2009 09:44 AM
Location Of Door Lock Interface Module? E55&98 Jeep ZJ Grand Cherokee Forum 1 10-30-2006 05:03 AM
Power Door Lock Buzz / Door Lock Duck Noise - Power Door Lock Actuator Solution Coppell-Jeep ZJ Grand Cherokee Forum 4 01-11-2006 10:25 PM
Need a Door Lock Module for 1994 ZJ adarrell ZJ Grand Cherokee Forum 3 09-28-2005 07:19 AM
