Where is an open fuse - JeepForum.com
post #1 of 8 Old 07-21-2012, 01:20 PM Thread Starter
cjhallmark123
I have been trying to wire my cb without having to goto straight to the battery, and i have no idea of how to wire into a fuse box or where an open fuse that is not already being used. i know of two fuse boxes and id prefer to stay inside because idk howto go through the firewall without drilling. im new at this.
cjhallmark123 is offline
post #2 of 8 Old 07-21-2012, 01:49 PM
Cameleer
Hook it up to the cigarette lighter wires if you want it to shut off when the key is turned off.
That's the way I did it.
Only those who will risk going too far
can possibly find out how far one can go.
Cameleer is offline
post #3 of 8 Old 07-21-2012, 01:58 PM
zander21510
I think this is how I wired mine up. If you look at the fuse diagram you can see where everything goes to. I wired my PA to the cigarette lighter fuse, my CB is actually an old base-station I inherited that gets way better reception than regular stuff that I use an adapter to the cigarette lighter to plug into...my driving/fog lights are wired I believe to my security fuse or something that I don't have.
This reminds me I need extra fuses....I don't think I have any left for replacements :P
zander21510 is offline
post #4 of 8 Old 07-21-2012, 02:10 PM Thread Starter
cjhallmark123
okay thank yall. im gonna try that
post #5 of 8 Old 07-21-2012, 02:57 PM
SKorch630
Or your fuel pump... Either works just fine. You can drill through your firewall (which I have done) just make sure you fill that hole with fire RESISTANT goop. I can show you what I did a bit later.. they also make grommets for a firewall hole which are essentially the same thing although they're fire retardant. 1. Flame resistant - The characteristic of a substance to resist ignition and to self extinguish if ignited.
2. Flame retardant - A chemical substance used to impart flame resistance. I can also show you how to wire it by staying inside the cab and going behind your dash to get to the fuse box.
SKorch630 is offline
post #6 of 8 Old 07-21-2012, 03:41 PM
Area.3.Fiftyone
I would just use the auxiliary power source wire right next to the cigarette lighter.
Unless they didn't all come with that. Maybe it's just a Limited thing?
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #7 of 8 Old 07-21-2012, 06:15 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
my aux power outlet is constant hot. cig lighter is switched acc.
ratmonkey is offline
post #8 of 8 Old 07-21-2012, 06:20 PM
SKorch630
same in mine.
98 ZJ Fuse Panel Description and mystery fuse spot? ZJ-Jeeper ZJ Grand Cherokee Forum 2 04-04-2011 08:14 PM
Red wire with fuse off of the fuse box? Eddmcm228 ZJ Grand Cherokee Forum 4 10-25-2010 11:48 PM
How do you open the panel to access the fuse box? warrenhaynes WK Grand Cherokee & XK Commander Forum 1 07-21-2009 05:44 PM
Can't Open tailgate - 97 JGC shockwave ZJ Grand Cherokee Forum 14 05-03-2008 09:33 PM
How to open bonnet without getting in car purple_jeep ZJ Grand Cherokee Forum 15 06-11-2007 10:49 PM
