Where is my speedometer gear??...It's gone!!! - JeepForum.com
post #1 of 3 Old 06-03-2002, 12:14 PM Thread Starter
James77
Okay, so found the wep page that details how to go about putting a new Speedo gear in the trans. if you put a lift kit/bigger tires and other mods that could effect the accuracy of your MPH.
Well, I have a 99' Jeep Grand Cherokee, with 4WD and 6cylinder. So I crawl under the jeep to look for where the cable plugs into the rear of the housing and it's BLOCKED OFF!!!....from the factory!!
So now what? What do I do!?? Where did they move it??
Thanks for any input,
James
James77 is offline
post #2 of 3 Old 06-04-2002, 10:18 AM
valkyr
Starting in 99, the Grand Cherokee no longer uses a speedo gear in the tranny. It's all computerized. There's a sensor on the rear axle that counts rotations and it sends information to the computer for calculating speed, miles per gallon, etc.
valkyr is offline
post #3 of 3 Old 06-04-2002, 10:37 AM Thread Starter
James77
Okay, that helps to explain things.
Thank you for your feedback...much appreciated.
James77 is offline
where is the speedometer gear!!! wjchristine ZJ Grand Cherokee Forum 21 09-26-2009 05:19 PM
Need a reasonably priced speedometer gear supplier. Brian's 97 ZJ ZJ Grand Cherokee Forum 2 09-03-2009 05:40 PM
Speedometer pinion gear ryandavenport ZJ Grand Cherokee Forum 5 04-23-2009 07:55 AM
Speedometer tire/gear chart jeepejeep ZJ Grand Cherokee Forum 0 02-25-2006 11:44 AM
Does WJ have Speedometer Gear ??? CinciSurWJ ZJ Grand Cherokee Forum 5 08-16-2005 05:46 PM
