Where is my speedometer gear??...It's gone!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Where is my speedometer gear??...It's gone!!!
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-03-2002, 12:14 PM   #1
James77
Okay, so found the wep page that details how to go about putting a new Speedo gear in the trans. if you put a lift kit/bigger tires and other mods that could effect the accuracy of your MPH.
Well, I have a 99' Jeep Grand Cherokee, with 4WD and 6cylinder. So I crawl under the jeep to look for where the cable plugs into the rear of the housing and it's BLOCKED OFF!!!....from the factory!!
So now what? What do I do!?? Where did they move it??
Thanks for any input,
James
James77 is offline   Reply With Quote Quick reply to this message
Unread 06-04-2002, 10:18 AM   #2
valkyr
Starting in 99, the Grand Cherokee no longer uses a speedo gear in the tranny. It's all computerized. There's a sensor on the rear axle that counts rotations and it sends information to the computer for calculating speed, miles per gallon, etc.
valkyr is offline   Reply With Quote Quick reply to this message
Unread 06-04-2002, 10:37 AM   #3
James77
Okay, that helps to explain things.
Thank you for your feedback...much appreciated.
